HELP!!! Cant find leak!?!?!?!
Old Jan 10, 2003 | 01:29 PM
vtec69's Avatar
Default HELP!!! Cant find leak!?!?!?!
I just installed a new headgasket on my ls/vtec and when i started it up nothing leaks. But when the car gets warmed up i see oil dripping from under the cam gears. So i put some high temp silicone on the corners of the valve cover and waited approx 14 hours and started it back up. After about 5-10 mins of idleing I saw oil dripping again from under the cam gears.
Could it be my cam seals????
Or is it maybe the silocone didnt fully dry and it gets melted when the car gets warmed up???
Please help me I miss my LS/VTEC
TIA
-Brian
Old Jan 10, 2003 | 01:30 PM
Spade's Avatar
Default Re: HELP!!! Cant find leak!?!?!?! (vtec69)
First thing that went through my head was cam seals.
But also consider VTEC solenoid gasket
[Modified by Spade, 2:31 PM 1/10/2003]
Old Jan 10, 2003 | 01:41 PM
Kataku2K3's Avatar
Default Re: HELP!!! Cant find leak!?!?!?! (Spade)
I'm thinkin replace the cam seals
Old Jan 10, 2003 | 01:42 PM
vtec69's Avatar
arent the cam seals on the same side as the cam gears???
And isnt the vtec solenoid gasket on the distrub. side??
-Brian
Old Jan 10, 2003 | 01:54 PM
Spade's Avatar
Yeah I'm not thinking......
Cam Seals is your best bet....pull the valve cover and see.
Old Jan 10, 2003 | 02:09 PM
vtec69's Avatar
EDIT: I meant oil seal not cam seal
-Brian
Old Jan 10, 2003 | 03:24 PM
Kataku2K3's Avatar
You can get away without any leaks even if you don't Honda Bond or high temp RTV the valvecover gasket... I'm still thinking the cam seals unless ur valvecover gasket is bad or you didn't Honda Bond the outer cam caps... Get it checked out, oil running all over the cam gears and then transfering to your timing belt is just going to wear it out faster... Latez
Old Jan 10, 2003 | 04:56 PM
Honda4CX-T's Avatar
Sounds like you've pinched your valve cover gasket some and/or you did not use Honda-Bond "HT" correctly.....
antballs420
Feb 17, 2006 01:41 PM
elitetuning
Nov 28, 2005 07:34 PM
vtec69
Jan 10, 2003 05:28 PM
vtec69
Jan 10, 2003 02:06 PM
