knock sensor
Old Jun 21, 2002 | 11:39 AM
22civic's Avatar
Default knock sensor
if my knock sensor is busted will my vtec work. i found out my sensor was broken and mabe thats why my vtec is not opening
Old Jun 21, 2002 | 12:15 PM
YeuEmMaiMai's Avatar
Default Re: knock sensor (22civic)
no, not unless you got a hacked ECU
Old Jun 21, 2002 | 12:32 PM
Smashback's Avatar
I have an EX ECU on my D16Y7 w/D16Y8 head. There is no knock sensor at all, so obviously it's not hooked up, and VTEC works fine. Of course I haven't heard it at all since I put the turbo on...
Old Jun 21, 2002 | 12:38 PM
Katman's Avatar
YES, vtec WILL work if you don't have your KS hooked up. it's not one of the vital components in making vtec work. although these components or sensors are:
VSS
VTEC pressure switch
VTEC solenoid
Coolant temp
...btw, you car has to be up to normal operating tempature & above approx. 30-40mph in order for vtec to kick on.
Old Jun 21, 2002 | 04:45 PM
22civic's Avatar
so it should work then
04silvep3
Nov 12, 2008 12:50 PM
BEATINTEGRA
Dec 5, 2007 03:05 PM
h22ek9forme
Nov 12, 2007 10:48 AM
B18cHatch06
Sep 30, 2005 11:39 PM
Brick Top
15
Oct 28, 2004 10:48 PM
