VAFC2 Question
k i wired it up, and went thru the inital setup, the car runs rough and idles at 600-700, also the car jerks a bit when driving, like its going to stall even tho i have my foot on the gas...help plz
did you set the sensor input 6 - in and 6 - out? and also make sure you hook up the VTM wire. Check the Air Flow wires are in the right connection (if you reverse the wires might have some performance issue)
Yosshaa
Aug 7, 2003 09:02 PM
thanks
