v-tec not working
Old Jan 20, 2005 | 05:23 PM
92lsvteceg6's Avatar
Default v-tec not working
i just put a b16sir2 in my 90 integra and i cant get v-tec to work there is no check engine light on and i checked my ground and syleniod they are fine can anyone help me?
Old Jan 20, 2005 | 06:20 PM
kid-honda's Avatar
Default Re: v-tec not working (sick95civic)
Its VTEC and solinoid.
I dont understand how you can not be getting a code? aside from no VTEC does it seem to run fine? are you sure the solinoid is getting oil pressure? power?
Old Jan 20, 2005 | 06:49 PM
Default Re: v-tec not working (kid-honda)
thank you for the grammar lesson yea i checked that **** already
Old Jan 20, 2005 | 06:53 PM
kid-honda's Avatar
Are you being sarcastic?
Well if you have power, a constant ground and full oil pressure on the solinoid and no codes it must be working fine.
What makes you think its not working?
If you have a stock GSR its not loud with the oem intake.
Old Jan 20, 2005 | 07:05 PM
i dont know you tell me, its not stock and if you drive vtec cars you can feel when vtec works
Old Jan 20, 2005 | 07:06 PM
You_Get_Vapors
Guest
Posts: n/a
Do you have a VTEC ECU? Harness? You might have to wire it for VTEC.
Old Jan 20, 2005 | 07:08 PM
Default Re: v-tec not working (You_Get_Vapors)
thanks but i did already everything is wired and plugged in
Old Jan 20, 2005 | 07:15 PM
kid-honda's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sick95civic &raquo;</TD></TR><TR><TD CLASS="quote">i dont know you tell me, its not stock and if you drive vtec cars you can feel when vtec works </TD></TR></TABLE>
OK, well considering most vehicles I have owned i have put a VTEC motor in or have come with one from the factory I would assume I know what it feels and sounds like.
Well you need to give more info.
You have sid it has no codes and all groungs are good, oil pressure is good and the solinoid is working, what else can i tell you.
Are you sure your wiring is 100% correct?
Old Jan 20, 2005 | 07:20 PM
97itr86's Avatar
Bad solenoid? What is the ID code on the side of the ecu? Are you letting it warm up? Also with a B16 Vtec isn't that loud or real noticeable unless you are using different cams.
Old Jan 20, 2005 | 07:30 PM
sleepinbeauTEG's Avatar
Default Re: v-tec not working (97itr86)
did u check your oil, and make sure the car is warmed up cause it wont work if its not warmed up or u have no oil. u prolly just didnt hook up vtec correctly
Old Jan 20, 2005 | 07:33 PM
TrakDay's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97itr86 &raquo;</TD></TR><TR><TD CLASS="quote">Bad solenoid? What is the ID code on the side of the ecu? Are you letting it warm up? Also with a B16 Vtec isn't that loud or real noticeable unless you are using different cams.</TD></TR></TABLE>
that's my guess
red-eg6
Jul 13, 2005 11:25 PM
b16mike
May 13, 2005 09:51 PM
Ch3mik
20
Mar 30, 2005 11:56 PM
Nsane1
Jun 12, 2004 04:47 PM
vspec12
Nov 5, 2001 05:25 AM
