tips for removing O2 sensor from header?
Old Jul 4, 2002 | 05:54 PM
StyleTEG's Avatar
Default tips for removing O2 sensor from header?
I have to replace the O2 sensor in my header, and I would really rather get the sucker off with out pulling the whole header.
I tried it today and it did not go well. I had the deepwell O2 socket, but because of clearance neither a rachet or a braker bar had enough room for me to try and pop it off. So I tried the other O2 socket I have, which is shorter and slightly different, but again I had no room to get it off with a braker bar nor a rachet.
So finally I tried an appropriat sized wrench, but I could not get it off (even after soaking it in PB Pentrating liquid). The only thing I can think of is maybe use a pipe on the end of the wrench for more leverage?
Any other ideas? Thanks in advance.
Old Jul 4, 2002 | 06:17 PM
comptechgsr2000
Guest
Posts: n/a
Default Re: tips for removing O2 sensor from header? (StyleTEG)
Turn the wrench counter clockwise.
Old Jul 4, 2002 | 06:28 PM
StyleTEG's Avatar
Default Re: tips for removing O2 sensor from header? (comptechgsr2000)
Is that what you are supposed to do with it? I thought you were just supposed to hit the O2 sensor with it till it came off
Thanks for the bump though
Old Jul 4, 2002 | 10:58 PM
94civicx's Avatar
New User
I used a crescent wrench and a hammer. Put the wrench on and then hammer it in the correct direction and it gives it enough torque to break the o2 sensor loose
Old Jul 5, 2002 | 04:51 AM
StyleTEG's Avatar
Default Re: tips for removing O2 sensor from header? (94civicx)
Good idea, I will have to give that a shot. Thanks much
Old Jul 5, 2002 | 12:43 PM
94civicx's Avatar
New User
no problem
Old Jul 5, 2002 | 10:05 PM
Sh!+F@ce's Avatar
yup thats what i did too.... pipe idea for a longer lever arm could work too.... wither way just make sure you don't round off the O2 sensor if its rusted intoo bad. liquid wrench liquid wrench liquid wrench
Old Jul 5, 2002 | 10:28 PM
bullz's Avatar
Default Re: tips for removing O2 sensor from header? (****F@ce)
I unplugged that beotch (from the electrical connection above) because I couldn't unscrew it. Then I took it off having all the space and leverage. Screwed the O2 it back on to my new header then after it was installed, I plugged it back in.
orourkeusn
Honda Civic (2006 - 2015)
Jul 5, 2008 04:02 AM
simplypinoyy
14
Jul 26, 2004 07:50 PM
icon_race_eg
14
May 5, 2004 05:49 PM
f1uxx
May 8, 2003 09:45 PM
Black R
Feb 12, 2002 04:38 PM
