tips for removing O2 sensor from header?
I have to replace the O2 sensor in my header, and I would really rather get the sucker off with out pulling the whole header.
I tried it today and it did not go well. I had the deepwell O2 socket, but because of clearance neither a rachet or a braker bar had enough room for me to try and pop it off. So I tried the other O2 socket I have, which is shorter and slightly different, but again I had no room to get it off with a braker bar nor a rachet. So finally I tried an appropriat sized wrench, but I could not get it off (even after soaking it in PB Pentrating liquid). The only thing I can think of is maybe use a pipe on the end of the wrench for more leverage? Any other ideas? Thanks in advance. |
Re: tips for removing O2 sensor from header? (StyleTEG)
Turn the wrench counter clockwise. http://images.zeroforum.com/smile/emthup.gif
Re: tips for removing O2 sensor from header? (comptechgsr2000)
Is that what you are supposed to do with it? I thought you were just supposed to hit the O2 sensor with it till it came off http://images.zeroforum.com/smile/emwink.gif
Thanks for the bump though |
I used a crescent wrench and a hammer. Put the wrench on and then hammer it in the correct direction and it gives it enough torque to break the o2 sensor loose
Re: tips for removing O2 sensor from header? (94civicx)
Good idea, I will have to give that a shot. Thanks much
no problem
yup thats what i did too.... pipe idea for a longer lever arm could work too.... wither way just make sure you don't round off the O2 sensor if its rusted intoo bad. liquid wrench liquid wrench liquid wrench
Re: tips for removing O2 sensor from header? (Sh!+F@ce)
I unplugged that beotch (from the electrical connection above) because I couldn't unscrew it. Then I took it off having all the space and leverage. Screwed the O2 it back on to my new header then after it was installed, I plugged it back in.
