o2 sensor stuck?
o2 sensor stuck?
my o2 sensor is stuck? how should i try getting it off? it seems that it siezed up.
any good ideas on how to un stuck it.
Re: o2 sensor stuck? (7PSI CRX)
first take the header off the car.
Then take a proper fitting 6pt wrench, Hold the exhaust in a vice. Tap the end of the wrench with a hammer.
A torch can help
-Eric
A torch can help
-Eric
Re: o2 sensor stuck? (mac13_34)
oxy acetylene. if you take the header out as suggested you should'nt need the torch. just get a good wrench on it and tap with hammer, also suggested, it should unstick.
Global Moderator
No need for the torch..
1) soak the threads in wd-40 do NOT get it on the actual O2 sensor
2) next day go and buy the O2 sensor sock (picture posted above)
3) Use an impact wrench and viola!
4) Good luck because your going to need it..it took me a while but i got it
The socket is only 9.99 at autozone
Re: (Usdmdc2)
I never knew that socket was so cheap. I always had a friend stand on the header or cat and then I would use an open ended wrench and put my foot to it. Works like a charm.
mine was stuck a while back aswell
run the car so it gets hot, like really hot
hit it with some liquid wrench
unplug the o2 and use a closed box wrench on it
Re: (BlackCRX)
when mine died in the stock manifold, i just bought a header. but with a wrench, some penetrating oil and some heat, you'll be able to get it out.
-spenc
-spenc
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mac13_34 »</TD></TR><TR><TD CLASS="quote">if i take of the header will i need to replace the gesket? think itll take me long?</TD></TR></TABLE>
I would recommend changing the gasket.
Re: o2 sensor stuck? (B2FiNiTY)
You dont have to change the gasket.
If it starts to seperate then you might want to.
Ive ran 3 different headers with the same gasket, still good. Just torque to spec dont overtighten thinking it will seal better
-Eric
-Eric
Re: (Usdmdc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Usdmdc2 »</TD></TR><TR><TD CLASS="quote">No need for the torch..
Wd-40 is not a penetrating lube, pb blaster and liquid wrench is. You should only need the socket though.
tek_civic
16
02-19-2003 09:58 PM
