TCS / Check Engine light - Honda-Tech - Honda Forum Discussion
Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 USA Accord and Inspire
Old 08-27-2011, 05:47 PM   #1
Default TCS / Check Engine light
So I have a 2004 Honda Accord LX ( V6 ) with about 100K miles. While driving today the TCS light/a harzard looking light/check engine light all came on at the and the engine began hesitating. After coming to a complete stop , the car was very very slow to accelerate. I had to pull over because I was slowing traffic. When I turned the engine off and then back on the TCS/hazard looking light were off but the check engine light remained - but the car ran fine. Has anyone has this same experience and if so what the heck is going on?
TeamSumner is offline   Reply With Quote
Old 01-13-2012, 04:03 PM   #2
philly-honda's Avatar
Default Re: TCS / Check Engine light
same here but when i hit the pedal it does not rev
philly-honda is offline   Reply With Quote
Old 01-13-2012, 04:57 PM   #3
#1 Super Guy
94eg!'s Avatar
You had an intermittent failure of some kind that causes the car to run funny. May have been bad enough to put the ECU into limp mode.
When you shut it off, it reset everything and the problem did not re-occour. The check engine light is still on to tell you that there was a problem and OBD codes were generated. This light will stay on until you have someone check the ECU with a code reader and then clear the codes. If the problem returns, the lights will come back on.
The local auto parts store will check the codes for you. You should write them down and come back on here and google the numbers specifically for Hondas. Some code numbers are generic, and some mean different things for different brands. The parts guy can only tell you their generic meaning.
They typically will not clear the codes for you, but they should let you do it yourself. Some consider this cheating emissions, but clearing codes is always to the 1st step in diagnosing a problem. This is so you can see if they come back again.
94eg! is offline   Reply With Quote
Old 01-14-2012, 05:40 AM   #4
My Name is Nobody
MSchu's Avatar
that's probably the "Limp Mode" OP... it means pull over to a safe place and do not keep driving, take to a dealer/shop asap.
MSchu is offline   Reply With Quote
Old 01-14-2012, 08:45 AM   #5
Good luck with your car, my last honda had "intermittent" failures but wouldn't trow any codes, I'd run fine for a month then start acting up.........sold that car.
car detailing san luis obispo
san luis obispo auto detail
auto detail san luis obispo
ckfab is offline   Reply With Quote
Old 09-21-2014, 11:51 AM   #6
kingrukus's Avatar
Did you ever figure out the problem? I am having the exact same problem.
kingrukus is offline   Reply With Quote
Old 09-27-2014, 10:05 PM   #7
Accelerator pedal position sensor is my guess. Mine went bad at about 170k and would cause those problems intermittently and more frequently over time until it became necessary to replace it. It's a simple bolt-on part.
johnnyb588 is offline   Reply With Quote
Old 09-29-2014, 05:14 AM   #8
kingrukus's Avatar
Turns out that the main ABS unit fixed my problem. Had it fixed last week and was able to drive it from Toronto to NYC and back without any issue.
TCS and Check Engine P7040 and P1676 codes rahulmunjal Honda Accord (1990 - 2002) 0 02-25-2012 10:42 PM
TCS & Brake Light Petiej Honda Accord & Crosstour (2003 - 2012) 3 09-16-2010 05:04 AM
Acura Code p1607 and PCS light rk-acura2000tl Acura TL, RL & ZDX 0 12-13-2008 08:48 AM
Traction Control problems Zani Honda Prelude 5 11-21-2005 12:56 PM
Tags
04, 2003, 2004, accord, acura, cel, check, civic, codes, coming, engine, honda, light, lightand, tcs, tl, tsx
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
Question Title:
Description:
