is there anyway to lower temperature?
#52
Re: (FuknHeeHAw)
Intake air temps would cause a motor to ping more than coolant temps, if any at all. If you're running at "40%" on the temperature range you SHOULD NOT have pinging, doesn't matter if you're running higher compression. There's plenty of high compression motors running stock t-stat with no pinging. G'luck on findind out your problem
#53
Re: (R-Lug)
that's not true. ping or knock is high cylinder temps caused but too far advanced timing,low octane fuel, or really warm intake air which can all occur with 40 percent on the temp gauge. my temp gage never past 40% and i've pinged because of a bad Knock sensor.
#54
76.169.175.137
Re: (99Geeezer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99Geeezer »</TD></TR><TR><TD CLASS="quote">that's not true. ping or knock is high cylinder temps caused but too far advanced timing,low octane fuel, or really warm intake air which can all occur with 40 percent on the temp gauge. my temp gage never past 40% and i've pinged because of a bad Knock sensor. </TD></TR></TABLE>
well as for me..it's pinging because of the fuel im running, im supposed to run atleast 93 octane...
i was driving today, and let me tell you....it is lagging like a bitch, it feels as if the timing is way off, im going to NOT touch the motor until i have enough money to tune it again..thanks for all your help H-T
macdaddydelux
11-09-2007 07:23 AM
EH2 on Steelies
16
02-28-2006 12:15 PM
fridexter
11-20-2004 02:52 PM
