Testing continuity on tps connection.. help
Old May 23, 2008 | 04:59 PM
Ladiesx3Me's Avatar
Default Testing continuity on tps connection.. help
well im trying to figure out if my tps harness has a short somewhere maybe thats hwy it keeps throwing a code no matter how many times I replace the tps itself.
question is, with the connector off,
which two pins do i probe?
cause i probed the far right and far left which I believe are the Yellow/green and blk/green wires and that was the only spot I got a reading of like 2.00 or something.. no where else gets any continuity. the dvom stays at 1. (infin)
is this teh correct pins, and am i even testing the correct way? or do I test at ecu?
Old May 23, 2008 | 06:02 PM
inspiration's Avatar
Default Re: Testing continuity on tps connection.. help (Ladiesx3Me)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ladiesx3Me &raquo;</TD></TR><TR><TD CLASS="quote">well im trying to figure out if my tps harness has a short somewhere maybe thats hwy it keeps throwing a code no matter how many times I replace the tps itself.
is this teh correct pins, and am i even testing the correct way? or do I test at ecu?</TD></TR></TABLE>
In order to test the continuity of the wire. Let say for example you are testing yellow/green wire. So you have to put one probe on one side and the other probe at the other end. You either hear if you have a digital or see the needle going across if you have a analog meter. If you don't hear or see any movement from the meter then you have a short somewhere.
Old May 23, 2008 | 06:17 PM
Ladiesx3Me's Avatar
hmm so do you mean .. lets say i test the green/yellow.. i probe it at the connector.... and then at the ecu? cuz that wud be the start - finish of that wire..
civickid03
19
Feb 4, 2009 03:51 AM
Juan_Mitosis
Feb 4, 2008 04:39 PM
triton302
Mar 28, 2007 12:52 PM
HondaHeddie
Mar 18, 2007 02:15 PM
88 rex
Aug 31, 2006 08:24 PM
