A test for VTEC!!!
Old Dec 13, 2002 | 01:02 PM
  #26
drewspeed's Avatar
Default Re: A test for VTEC!!! (kAoTiK)
Can't hear it?
You could always hook up a test light to your vtec solenoid and when it kicks in it will/should tell you. Regardless, your check engine light will come on if it doesn't work or isn't "operational"
Old Dec 13, 2002 | 01:09 PM
  #27
Kelvin96GSR's Avatar
25 Year Member
Default Re: A test for VTEC!!! (drewspeed)
take off your airbox cover
you should hear it
Old Dec 13, 2002 | 01:54 PM
  #28
B00ST2nR's Avatar
http://www.we-todd-did-racing.com/we...MxeTU0MQ%3D%3D
Here's my stock GS-R, and I can hear the Vtec kicking in clearly.
Nice vid, I busted a nut when VTEC engaged. That **** was loud!
haha
Old Dec 13, 2002 | 02:20 PM
  #29
YNOT's Avatar
Default Re: A test for VTEC!!! (four27)
how would you know if you've achieved over 50lbs of oil pressure? when the engine is running at its normal temp? thank!
my VTEC is obvious to me and I have a 40% hearing loss. You should hear it and feel it. Remember you need over 50lbs of oil pressure for it to work so confirm you have good oil pressure.
Old Dec 14, 2002 | 02:41 PM
  #30
four27's Avatar
Default Re: A test for VTEC!!! (YNOT)
I just assumed you had an oil pressure guage and if not borrow a test guage and screw it into the sending unit hole just to the right of the filter.
Jimster480
17
Jul 27, 2010 12:39 PM
trav39562
Feb 4, 2009 05:41 PM
7808
Jan 24, 2006 08:35 PM
H22AJSPEC
Sep 4, 2003 12:56 PM
HorrorDog
Nov 11, 2001 09:32 PM
