temp gauge
Old Dec 26, 2009 | 01:43 PM
mr.jamrock's Avatar
Default temp gauge
change the tranny on my da teggy and now the temp gauge doesnt work. while the check engine light also comes on sometimes. any help?
Old Dec 26, 2009 | 02:07 PM
DJYoshaBYD's Avatar
Default Re: temp gauge
you maybe didnt hook up the temp gauge? lol.. some sort of wiring issue is afoot..
start checking ALL of your connections on your sensors, and the wiring, and ALL of your grounds, fuses, relays, etc...
go back through what you took apart in your mind, and look at it, and you may find the issue
I would say your gauge isnt working because of a bad connection to the temp sensor, which is a brittle, 1-wire sensor, under the dizzy (if im not mistaken.. correct me if im wrong)
Old Dec 27, 2009 | 07:05 AM
mr.jamrock's Avatar
I think its broken is it the one connected to the block? right under the dizzy?
GeneBEllis
May 7, 2013 07:01 AM
s13hero
Aug 22, 2011 07:34 AM
TurboJesse
Sep 25, 2003 04:15 AM
erniecars
Jun 14, 2002 11:48 PM
pmachan
Aug 9, 2001 06:43 AM
