tech question obd1 H22a swap in 95integra. please help!!! LS
Old 01-28-2010, 03:49 PM
Weakbyyou's Avatar
Default tech question obd1 H22a swap in 95integra. please help!!! LS
car runs fine, but when you step on the gas it backfires and sputters. ignition and fuel are good!
any suggestions will help!
timing was off. 2 plugs had anti-freeze on them
it is throwing codes
8-TDC Sensor (Top Dead Center)
defective circuit or unplugged / defective sensor
9-CYP Sensor (Cylinder)
21-VTEC Solenoid Valve
defective circuit or unplugged / defective solenoid valve
Old 01-28-2010, 05:22 PM
dothacker's Avatar
Default Re: tech question obd1 H22a swap in 95integra. please help!!! LS
... O2 sensor? my car was running fine till i put a highflow cat that eliminates the O2 sensor and it starts to backfire... but then again, i also installed a 3" exhaust so that could be my problem too... but check with your sensors.
Old 01-28-2010, 05:34 PM
Weakbyyou's Avatar
yea dont think that is it. have a feeling it is timing or maybe a bent valve. just thought i would throw it out there before i pulled the head!
Old 01-28-2010, 06:15 PM
mouab18c1's Avatar
do a compression or leak down test before disassembling a motor
Old 01-29-2010, 09:29 AM
Weakbyyou's Avatar
gonna do that today
Cap'N Chronic
12-03-2011 05:44 AM
Jwbetley
Engine Management and Tuning
11-15-2008 04:44 PM
No_Limits_Accord
07-09-2008 06:44 PM
jdm00civicex
11-12-2006 02:02 PM
dominate9
12-21-2002 06:24 PM
Quick Reply: tech question obd1 H22a swap in 95integra. please help!!! LS
