clutch problem. please help.
this morning when i went to turn the car on the clutch was very very loose. also when i tried to put it reverse it grinded the gears, so i pumped the clutch a couple of times and then it finally went into gear. after driving for a while it got somewhat back
Re: clutch problem. please help. (enzozenuni)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by enzozenuni »</TD></TR><TR><TD CLASS="quote"> this morning when i went to turn the car on the clutch was very very loose. also when i tried to put it reverse it grinded the gears, so i pumped the clutch a couple of times and then it finally went into gear. after driving for a while it got somewhat back </TD></TR></TABLE>
check you fluids, master slave cylinder might be low
Yep.. sounds like a fluid leak. Check the lines from the slave cylinder to the clutch master cylinder. Also check inside the car, sometimes the boot on the clutch master cylinder leaks.
Good Luck
Chris
Good Luck
Chris
g2turbo
01-17-2012 03:15 PM
phatsindabuildin
03-25-2008 06:57 PM
