Sticking door lock problem..
Old Jul 30, 2003 | 10:50 AM
specie's Avatar
Default Sticking door lock problem..
Sometimes I have a problem with the driver's side door lock sticking...sometimes it doesn't lock when I use my alarm and I'd have to use the key to lock it. Where is a good place to spray some white grease or what can I do to fix this problem. Thanks.
Old Jul 30, 2003 | 11:02 AM
tilt's Avatar
Default Re: Sticking door lock problem.. (specie)
i would take the door panel off and take a good look at the latch assembly. Grab the metal rod that locks and unlocks the door and move it back and forth to see if it is snagging somewhere.
Old Jul 30, 2003 | 11:05 AM
Toda Built's Avatar
mine does the same thing. I'm pretty sure that the motor for the lock is going dead. I plan on changing the motor out real soon.
Old Jul 30, 2003 | 11:16 AM
S1ERRA's Avatar
mine has the same problem... i hate that shiat!! its been doing this for a while now... i just lock it from the inside before i close the door...
Old Jul 30, 2003 | 11:19 AM
S1ERRA's Avatar
found a solution on team-integra.net : http://www.team-integra.net/fo...earch
Old Jul 30, 2003 | 11:55 AM
detaude's Avatar
Yeah, me too, just about every other teg has this problem, have to open your panel and mess with the metal rod and locking mechanism, I did it, and it worked again.
Old Jul 30, 2003 | 12:13 PM
JadeDM's Avatar
I get this on both doors.....! its very annoying indeed
J.WOLFE~v1.0
Dec 23, 2010 04:23 PM
aznboydat2
Acura TSX
Aug 13, 2008 06:13 AM
97RSTEG
Jul 11, 2006 08:05 AM
gsr98teg
Feb 4, 2004 06:09 PM
