Starting Problem
Old Nov 22, 2007 | 09:40 PM
bg-33p's Avatar
Default Starting Problem
I've searched but i'm pretty sure this is a unique case..so my car has been having a reoccuring problem of not starting. Just had maintenance done (i.e. spark plugs, starter. etc.) and i could usually jump start it. Then one day i wouldn't start/crank and i couldn't jump it. I took the battery out and tested out fine at Kragen's so this left me stumped...so i just let the car sit there for about 2 months while commuting on bike. Every week i would test it and still no start or anything. Then after the week hitting 2 months it decides to start, so im like wtf? I have no idea what's going on with the car can anyone help?
cliffs: car wont start for 2 months, i try to start it once every week no luck, today after 2 months car decides to start. i needz the halpzz plzz!
Old Nov 23, 2007 | 05:15 AM
God-Driven's Avatar
does it turn over, or does it make any noise at all, was the car doing this before you did any of the maintnance, also what year integra.
Old Nov 23, 2007 | 09:57 AM
bg-33p's Avatar
Default Re: (God-Driven)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by God-Driven &raquo;</TD></TR><TR><TD CLASS="quote">does it turn over, or does it make any noise at all, was the car doing this before you did any of the maintnance, also what year integra.</TD></TR></TABLE>
It makes a small "whhrrrr" sound, sorry bad description but best i can do it may be the fuel pump priming but not quite sure. And no crank or turning over, just that small whhhr sound. And the car wasn't doing this before the maintenance. 1994 gsr, thanks for the reply.
Old Nov 23, 2007 | 12:43 PM
IZEONLI's Avatar
Default Re: (bg-33p)
do a compression test on it
Old Nov 23, 2007 | 01:13 PM
Perfectionist's Avatar
Default Re: Starting Problem (bg-33p)
Either a poor connection at the battery posts, at the ground point, or at the starter. If those pan out, the starter solenoid may be sticky. After that is ruled out, suspect the starter itself. This is assuming any starter interlocks like clutch switch or auto trans shifter switches are funtioning normally.
Old Nov 23, 2007 | 03:04 PM
bg-33p's Avatar
Default Re: Starting Problem (Perfectionist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Perfectionist &raquo;</TD></TR><TR><TD CLASS="quote">Either a poor connection at the battery posts, at the ground point, or at the starter. If those pan out, the starter solenoid may be sticky. After that is ruled out, suspect the starter itself. This is assuming any starter interlocks like clutch switch or auto trans shifter switches are funtioning normally.</TD></TR></TABLE>
Starter was replaced not more than 6 months ago, but i suspect that as the problem also..but update:
i called AAA for road assistance, and the guy wasn't able to normally jump start it. Battery checked out good and nothing seemed abnormal. So he took a 1.5 - 2 ft socket wrench and smacked the starter while i kept turning the key and it eventually started. WTH? and while he was hitting the starter he said sparks were flying, so wth could this be?? i've never heard of anything like this..thx for the help all.
Old Nov 23, 2007 | 05:00 PM
g3integragsr's Avatar
* B A N N E D *
Your starter is bad. If it was replaced 6 months ago then it should still be under warrenty. If you had to smack it to start the car then its the problem. Gauranteed.
Is it Oem?
Old Nov 23, 2007 | 07:39 PM
bg-33p's Avatar
Default Re: (g3integragsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g3integragsr &raquo;</TD></TR><TR><TD CLASS="quote">Your starter is bad. If it was replaced 6 months ago then it should still be under warrenty. If you had to smack it to start the car then its the problem. Gauranteed.
Is it Oem?</TD></TR></TABLE>
Damn..ya the AAA guy took about a 2 ft socket wrench and banged the hell out of it before it was able to start. Not sure if it's oem, took it to a local mech...he'll be hearing from me
Old Nov 23, 2007 | 09:43 PM
bigislandc2's Avatar
looks like you have a bad ground. i've seen many of my friends try to do swap and r&r trans and after its all done they.
attempted to start and no luck, look at the car notice there is a loose ground on the trans cleaned it up and secured vehcile started right up!!
explosive
Aug 21, 2009 04:30 AM
everlight44
Feb 7, 2009 11:35 AM
Tenji
May 1, 2008 09:41 AM
Jet Black
Sep 10, 2003 07:07 PM
