starter problem need help?
Old Aug 28, 2007 | 05:38 PM
DC4 Rasta's Avatar
Default starter problem need help?
i just put a b16 in my teg and it started up fine everything is good. drove it around the block and turned it off. when i tryed starting it 10 min later it wouldnt start. i hear my starter spinning but it not ketching on the flywheel. i banged on the start still no good. any ideas or has anyone experinenced this.
Old Aug 29, 2007 | 09:59 AM
DA9_DAD's Avatar
Default Re: starter problem need help? (DC4 Rasta)
It could be a number of things.
Are you getting a CEL light or code?
Did you hook up all of the hoses correctly?
If you put an engine cleaner and hosed it off, you may want to remove the spark plug wires and plugs and crank it without them in to push any residual water through the chambers, dry it off completely, and check the dizzy.
Or, you may have a bad dizzy altogether, see if you can borrow one from a friend and see if that solves your problem.
good luck
Jeff5959
Sep 22, 2015 06:21 AM
Honda13
May 13, 2009 08:36 AM
DC4 Rasta
Aug 29, 2007 07:03 PM
DC4 Rasta
Aug 28, 2007 06:52 PM
fluffy
Nov 7, 2002 04:29 PM
