Engine Won't fire?!??!
Old Nov 7, 2002 | 09:36 AM
fluffy's Avatar
Default Engine Won't fire?!??!
My car hasn't started in 5 days now. It's been colder lately, and it looks as if my coolant is low. It turns and turns and turns, but never fires up. Any suggestions to what it could be? Oil is fine, plugs/wires are ok... any ideas please help!!
Old Nov 7, 2002 | 09:44 AM
Chiovnidca's Avatar
Default Re: Engine Won't fire?!??! (fluffycivic)
Does it have spark?
Old Nov 7, 2002 | 04:29 PM
PnX-R's Avatar
Does the Starter try and crank over fast or slow??..
Fast means that it's probably not your Starting Circuit and could be some other system causing the problem..
Slow means that there's High Resistance in the Second Starting Circuit.. I'd check the Starter Solenoid and make sure that there's Source Voltage at Crank coming out to the B Terminal and out the M Terminal..
Let me know how it goes.. GOod Luck!
Type_R_Lover
Jan 19, 2010 06:19 PM
Honda13
May 13, 2009 08:36 AM
PurEvl
Dec 11, 2005 05:55 PM
sirb18a
Feb 4, 2004 10:44 AM
joblow
Feb 20, 2003 09:18 AM
