starter?
Old May 22, 2006 | 09:51 PM
caliek4's Avatar
Default starter?
my friend has a 91 LS and for some reason out of no where the car will only stay on if you hold the key in the on position. if you let the key go it comes back to the off position and turns off the car. could this be a bad ignition or starter?? or something else??
Old May 23, 2006 | 03:03 AM
god.loves.ugly
Guest
Posts: n/a
Default Re: starter? (caliek4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by caliek4 &raquo;</TD></TR><TR><TD CLASS="quote">my friend has a 91 LS and for some reason out of no where the car will only stay on if you hold the key in the on position. if you let the key go it comes back to the off position and turns off the car. could this be a bad ignition or starter?? or something else??</TD></TR></TABLE>
not the starter... because obivously the car starts. sounds like an electrical problem. possibly the ignition
Old May 23, 2006 | 01:25 PM
caliek4's Avatar
Default Re: starter? (so.dark.the.con.of.man)
bump
Old May 23, 2006 | 04:00 PM
caliek4's Avatar
bump
Old May 23, 2006 | 11:05 PM
caliek4's Avatar
bump
Old May 24, 2006 | 07:24 AM
00BoostedGSR's Avatar
yea ur starter is fine but im 99% sure the problem is in ur ignition itself or the wires
Old May 24, 2006 | 10:06 AM
caliek4's Avatar
Default Re: starter? (00BoostedGSR)
so do i have to replace the whole ignition? or just some wires?
Old May 24, 2006 | 10:12 AM
__oversea's Avatar
how is your key??
Old May 24, 2006 | 12:54 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Does it seem to start and run for like half a second then shut off immediately? Do things like windows or wipers that normally work only when the key is on, work if you hold the key in start and crank the car? If so, the problem is your ignition switch and harness (the part that the key cylinder turns). I had to replace mine a few weeks ago after my car died and left me stranded, it was only about $35 for the part and $25 to ship it overnight.
Old May 24, 2006 | 02:40 PM
Code's Avatar
Not now Chief, I'm in the F'n zone!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00BoostedGSR &raquo;</TD></TR><TR><TD CLASS="quote">yea ur starter is fine but im 99% sure the problem is in ur ignition itself or the wires</TD></TR></TABLE>
Old May 28, 2006 | 03:20 PM
your better off getting a whole new ignition which isnt that bad, and you get a differnt key so any others floating around are useless
Old May 28, 2006 | 07:35 PM
JDM-EJ1's Avatar
Default Re: starter? (d-a-n-t-e)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d-a-n-t-e &raquo;</TD></TR><TR><TD CLASS="quote">
not the starter... because obivously the car starts. sounds like an electrical problem. possibly the ignition</TD></TR></TABLE>
This is what happened in my ex-girlfriends' Accord. It was the ignition module switch within the ignition.
Old May 30, 2006 | 10:08 PM
cao's Avatar
cao
or if you wanna save some money you can check take off the steering cover and see if any of the wires near the ignition are loose.
happened to me with my 240
Old May 30, 2006 | 10:21 PM
acurarock17's Avatar
lol, a bad starter just wouldn't crank the engine... the key cylinder is effed up or something, check a dealer if there's any technical service bulletins about it.
Old May 31, 2006 | 08:08 AM
RX3's Avatar
RX3
Default Re: starter? (acurarock17)
You can change just the switch it unbolts off the key part of the switch. Or you can buy the hole switch and change key out so you keep he same key.
Old May 31, 2006 | 10:16 AM
TRE_'s Avatar
Default Re: starter? (RX3)
ya sounds like the electrical portion of your ignition switch is going\gone bad .. ~$45 MSRP at a dealership... not hard to replace.
battleREADYb20
Apr 30, 2009 02:36 AM
mord
Sep 1, 2007 08:05 AM
EJ1 wilcox
Apr 25, 2005 02:25 PM
slammedtegls
Sep 24, 2004 07:05 AM
surfsup3841
Apr 11, 2002 08:37 PM
