Starter Problems?
Old Apr 11, 2002 | 06:36 PM
surfsup3841's Avatar
Default Starter Problems?
My 91 accord hasn't been starting to well the last few days. Sometimes the engine would turnever but the car just wouldn't crank but if I gave it a few it would start just fine. But today I was going down the road and the car just died. So i got off to the side and tried to start it but no luck. It turns over and starts really quick but then dies. I was able to keep the car going by turning the key and holding the key when i turn it. I would let it out just enough to keep the starter from staying engaged and just hold it there and the car will stay cranked. But as soon as I let it go the car dies on me. Everything sounds smooth while im holding it, is this the starter? Also what can I do about it. Any help is appreciated!!
Old Apr 11, 2002 | 06:37 PM
CmptchAV6's Avatar
Default Re: Starter Problems? (surfsup3841)
sounds like you have a faulty ignition and the part where you put the key into is broken and killing the car as if you turned the car off.
Old Apr 11, 2002 | 06:55 PM
Yea, I was also thinking maybe some part could be screwed up with the ignition. Could anyone enlighten me? Thanks guys!
Old Apr 11, 2002 | 07:04 PM
PorscheGT2's Avatar
New User
Its your ignition, i had to the same problem with mine a while ago. Theres an electrical part of the ignition switch thats bad, you'll have to replace this electrical part. It'll cost about $150, parts and labor. Hope this helps.
Old Apr 11, 2002 | 07:24 PM
Do you remember what the part was exactly?? Would this be difficult to do w/o taking it to a garage. I usually have a couple of friends help me out with stuff like this unless it's to complicated.
Old Apr 11, 2002 | 07:36 PM
PorscheGT2's Avatar
New User
well i took it to the shop and they didn't tell me exactly what it was the replaced, just that it was there was a part in the ignition that was bad. sorry i couldn't be more help.
Old Apr 11, 2002 | 08:24 PM
4doorH22's Avatar
I just changed my clutch and flywheel and rebuilt my own axles this weekend, but with a problem like yours I'd probably take it to a good mechanic. At least for an estimate. YOu could probably just replace the whole ignition/tumbler/key thing, but then you've have separate keys for doors and ignition.
Old Apr 11, 2002 | 08:37 PM
Default Re: Starter Problems? (4doorH22)
yea im going to take it to the shop. I read up on it and ignition looks complicated. gonna get it to the garage early in the morning, hopefully they will be able to finish it so I don't have to do without all weekend
kjrayo18
Nov 16, 2015 08:26 AM
doubleoazn03
14
Aug 27, 2010 12:19 PM
everlight44
Feb 7, 2009 11:35 AM
RichEd223
Sep 7, 2008 07:26 PM
reelhybrid
Feb 1, 2007 03:05 PM
