Squeaking coming from engine
true. I'd be curious to see if your pcv is stuck or plugged. would explain the build up of blow-by gases, but the valvecover slash cut in the intake would fix that, unless you don't have one still setup and the vc tube is blocked off/capped off.
I have an tube from my intake that goes into my valvecover. I'll try changing my PCV and seeing if it goes away. Hopefully it does because I don't know how to replace my piston rings or valve seats. =/
DyeBoi
Feb 16, 2006 04:27 PM
Another DAMN clutch problem....this time Its like I dont even have a cluth hooked up to my pedal....
Kasper.
Jul 29, 2002 10:31 PM
