speeedometer not working
Old Aug 10, 2008 | 08:02 PM
Nine0DA7's Avatar
Default speeedometer not working
OK HERES THE DEAL... I HAD THE HEATER HOSE CHANGE ON MY DA9 AND AFTER THE INSTALL MY SPEEDOMETER STOPPED WORKING ..... ANY SUGGESTION ON HOW TO FIX THIS WOULD BE HELPFULL
Old Aug 10, 2008 | 08:26 PM
lstek's Avatar
Default Re: speeedometer not working (Nine0DA7)
u probably rip out the speed sensor cable one the back of the tranny. check that first
Old Aug 10, 2008 | 08:30 PM
Nine0DA7's Avatar
Default Re: speeedometer not working (lstek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lstek &raquo;</TD></TR><TR><TD CLASS="quote">u probably rip out the speed sensor cable one the back of the tranny. check that first </TD></TR></TABLE>
oh thanx ... imma chek first thing tomoro morning
Old Aug 11, 2008 | 10:14 AM
anthonygauna's Avatar
my speedometer is doing the same thing but it was after i swaped trannys... its pluged in but still not working and my vtec wont kick in... plz help
Old Aug 11, 2008 | 10:40 AM
HONDRETTI's Avatar
Default Re: speeedometer not working (anthonygauna)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by anthonygauna &raquo;</TD></TR><TR><TD CLASS="quote">my speedometer is doing the same thing but it was after i swaped trannys... its pluged in but still not working and my vtec wont kick in... plz help</TD></TR></TABLE>
did you swap the same kind of tranny, or is it different?
Old Aug 21, 2008 | 05:42 AM
Default Re: speeedometer not working (HONDRETTI)
I HAD A GSR TRANNY AMD PUT A B16 TRANNY IN... BUT I TRIED BOTH THE B16 SENSOR AND MY OLD GSR SENSOR... DO U THINK IT COULD BE THE PLUG?
Old Aug 21, 2008 | 11:58 AM
dc2_97teg's Avatar
Well my first guess is to check your plug and also trace the wire. To see if you ripped anything or spliced it by any chance.
Old Aug 22, 2008 | 05:24 AM
Default Re: speeedometer not working (dc2_97teg)
thanks........... will do... any body else have any suggestions in case its not that...do u think the tranny could be bad.........
hoga113
Mar 8, 2013 04:32 PM
pin0y209
10
Jan 16, 2008 07:56 AM
Phaze2 Nick
Jun 5, 2005 09:24 PM
teamnvysionhb
Sep 20, 2004 10:20 PM
kim_2_da_chee
11
Oct 8, 2003 09:02 AM
