Spark plugs for B18B
What spark plugs should I get for B18B. Read other forums and they were talking about heat range and stuff I don't get, would be nice if someone could just recommend a spark plug for me. Thanks.
Re: Spark plugs for B18B
I don’t use anything but ngk plugs, plain ole copper cores. Just go to your local parts store and tell them you need plugs for your car, unless you have a pretty aggressive set up there’s nothing to benefit from running a different plug. If you do have a higher hp set up then some specs will be needed to determine what you might need
I use iridium plugs. The only benefit of using iridium is lifetime. Copper electrodes reach their service limit at 30k miles; iridium lasts 100k mi - as long as a timing belt. Use NGK part number BKR6EIX-11. They are gapped at 0.0515 in. You can order them online.
