Changing plugs.
Old Nov 23, 2001 | 09:35 AM
pub's Avatar
pub
Default Changing plugs.
Taking out the Bosch Plats for the stock Cu plugs because of some really bad gas mileage/power decreasing on my B18B. I was wonderin' if I just switched them would I be ok if I didn't check the firing of each cylinder or should I take it some place and have somebody do this?
Old Nov 24, 2001 | 06:46 AM
sutrusu's Avatar
Default Re: Changing plugs. (pub)
changing spark plugs is easy. dont pay someone else to do it. and dont use platinum plugs. copper is a better conductor, so it gives a hotter/better spark.
Old Nov 24, 2001 | 07:11 AM
Max GSR's Avatar
Default Re: Changing plugs. (sutrusu)
Platinum plugs all the way! That's what your engine was designed for! Platinum plugs ARE copper in the core just like full coppers, so there's no "better conductor" argument. The fine platinum electrodes are only at the end(s) of the core, are smaller and have a higher resistance than the coppers which gives the platinums a hotter spark across the electrodes, (remember resistance = heat) Much more efficient, not to mention longevity!
In any case, plugs are quite easy to change....
Bruce Banner
Sep 25, 2009 02:46 PM
Smokey5176
May 8, 2007 05:01 PM
