spark plug not igniting help
have just changed the motor in a 1990 integra with fuel injection to a 1.5 sohc non vtec have not been able to get it to start. i think it has something to do with the distributor, any ideas?
which pcm?
i'm not 100% on this, but i'm pretty sure, with non-obd, you can't use a dohc pr4 on a sohc pm6
if you're not getting spark, key on engine off, test for power at the blk/ylw tracer wire of the 2 pin distributor connector
right so i put the new coil in and started it up and it sounded like it was dieing so i turned it off and tried to start it again it turned over but didnt start i checked the coil again and this ones blown. a bit of a set back taking the coil back to get checked for mechanical fault, but i think its not the problem any ideas ?
