Solid Check Engine Light PR4-L11
Old May 23, 2026 | 12:42 AM
Garciamaxy's Avatar
Default Solid Check Engine Light PR4-L11
Hello Tech! My first post.. i tried finding people with similar issue but i havent found the solution to my problem just yet. I have a obd-1 PR4 that has a solid check engine light, I know it is not my jumper harness as I used a buddies obd1 ecu with my jumper and everything worked fine. I swapped IC17 and capacitors c14 and c21 already. Nothing! I check solder on Q10 and even resolder Q10 as well as QM3. Any help is greatly appreciated.!
Old May 23, 2026 | 08:12 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Solid Check Engine Light PR4-L11
Give up on that PR4 and find another ECU.
lgoodgrace
Apr 10, 2015 04:05 PM
Jk_DC2
Aug 19, 2009 11:08 AM
GsrRussell
Sep 24, 2008 08:32 AM
iluvmyEJ1
May 20, 2007 06:01 PM
