check engine light help!!!!
i just did a swap on my ej1 and the check engine light is on.... i put a b16a2 in my car with an obd1 engine harness and ecu (p-28). i did the the check engine light thing with a paper clip and the cel light just keeps flashing! any advice???
Re: check engine light help!!!! (iluvmyEJ1)
Well, my advice would be to count the number of flashes. That's what the hell it's supposed to do. Does it run okay?
Re: check engine light help!!!! (t0p_sh0tta)
i counted the light till it hit 150..... the list for codes only goes up to 92..... it runs great!!! i jus wanna pass e check
Ek Forever y0!
If it's really giving you a proper code, each long flash counts for 10's and each short flash accounts for a 1.
So say i had, 3 long flashes, and 4 short ones, that would be a 34.
Re: check engine light help!!!! (ek forever guy)
just to add on be a little more specific with the increments for long and short...
SHORT flashes are single digits (1/2 second)
LONG flashes are 10's (1 second)
hope this helps
hope this helps
Ek Forever y0!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iluvmyEJ1 »</TD></TR><TR><TD CLASS="quote">i counted 150 long flashes.......</TD></TR></TABLE>
That's a long time to count flashes, I'd have given up after 10.
Try a differen't ecu if you have one laying around. You might have a bad ecu or missed something.
what kind of ecu should i put??? its an obd2 b16a2 in a 94 ej1 (obd1) with the obd1 engine harness and ecu.... which obd1 ecu would work??
G. Man
12
02-25-2011 06:13 PM
