cheapest way toboost high
cheapest way to boost high
whats the cheapest way to boost higher like 12 on an ls with a turbo kit which includes a intercooler, bov, fuel reg and fuel pump without doing expensive internal work?...........Thanks
[Modified by NightHawkC5, 2:11 PM 1/10/2003]
Re: cheapest way to boost high (B00STeD)
just go ahead and do it and let us know how much it costs to rebuild your motor
it could be done and the motor may last 30k+ but dont count on boosting that high very often and being reliable
build the motor atleast forged rods and pistons and do it right the first time
Re: cheapest way to boost high (NightHawkC5)
the ls motor has low compression pistions any way. you need forged pistons! i boost 1 bar daily and have been doing so for a year. you need lots of fuel system upgrades, a reliable a/f gauge and great tuning either with a afc or standalone. it will last for a while but not forever.
[Modified by boostin b16, 11:18 AM 1/10/2003]
cheap? get some arp SOHC rod bolts and a good fuel system. i ran 15 psi in my LS for almost 2 years, and never blew the motor. I pulled the motor to put a built ls vtec in, but never had any probs.
Re: cheapest way to boost high (bgod)
u see i wan this BOV valve really badlly that is good for 10-35 psi so I wanted to see if i could boost higher to get it so how about just 10?
Re: cheapest way to boost high (FFgeoff)
It all depends on how well you tune it. Most people don't realize tuning involves everything from sizing your turbo to adjusting your timing. Everything has to be adjusted, and I do mean EVERYTHING...
[Modified by tweeked3rdgen, 11:57 AM 1/10/2003]
Location: You can be my wingman anytime...., Las Vegas, US
Re: cheapest way to boost high (Bryson)
Forgive me for not having a proper citation of this quote but, a fellow honda-tech member once wrote.
"Cheap - Reliable - Fast <---- PICK 2
....Again, sorry for not giving proper credit, but I forgot the persons name
-Will
-Will
Re: cheapest way to boost high (JeremyL)
Cheap? Maybe, Reliable? maybe
I've seen soo many 4g63 engines go boom....
most of the time due to an improperly serviced car.
Re: cheapest way to boost high (integra707)
-Will
-Will
-Will
-Will
Re: cheapest way to boost high (LS-hatch)
when it comes to FI nothing is that cheap specially if you want to be reliable.... i just come with the gain of power....and like the other say... pick two of those.. I seen the quote plenty of time to tell you that pretty much applies to any aspects of upgrading your car...
Re: cheapest way to boost high (lazerus)
Re: cheapest way to boost high (UberTeg)
wtf? I havent seen ONE blown 4g63. Its nearly impossible, the ECU retards ignition drasticly if you even breathe on the knock sensor. Maybe if you tried boosting 20 psi on 87 oct And DSM's arent as bad as you make them out to be reliability wise. You put 500 hp through a b-series tranny thats *magiclly* 4wd and see what happends. Do you realize how much torque is forced to the ground in 1st gear on an AWD car? Crankwalk owns the 2nd gens tho ^^
Re: cheapest way to boost high (Speed PHreak)
Your all wrong. If you use your BRAIN you can have cheap, fast, and reliable. You just have to think it out. Not to be a *****, but it's true. That old adadge was to keep everyone else from getting into it so they were the only 'COOL' ones with cars. That mas of an organ in your head is what you need to use in order to do anything right the first time. It's the best tool you have, use it. I'd just stick on this board to learn as much as possible.
When I first came into this scene I knew all about turbo's their efficiencies and their down falls, but I have owned quite a few Honda's and had no idea what some people were doing with them. Even going to the tracks across the country seeing all kinds of Honda's everywhere. I still had no idea that this many people were doing so many things with what very little was available. I learned from guys in Florida (mostly Puerto Ricans) what could be done with a little ingenuity. They could spend five hundred dollars on a car and get it into the low teens (12&13). This was in '95 -'96. It's always possible to go faster with the same amount of money. You just have to research more about efficiencies how different things effect efficiency. In the end the smartest guy will always win. You give the smart guy a lot of money he'll be unbeatable...
One word --Ingenuity-- that's all it takes.
If you flame me for what I say then you deserve to get whatever happens to you because of your actions and ignorance. Sorry for preaching I got carried away...
