Shifting problems
Hi all,
I have a 94 teg GS-R. I had tranny and clutch problems. When I shift to my 4th gear on high rev it doesn't go smooth and it cracks. So right after that I had clutch problems so i changed the whole deal. I installed a Exedy stage 1 organic clutch with a Type R flywheel. The car came out of the garage last week and the 4th still cracks. At the garage I had them change the 4th gear ring and the belonging synchro's. I still have the problems, when I shift into 4th gear on 5000 rpm it cracks.
Any suggestions of what might be the problem???
does crack mean grind??
is 4th the only one that does it??
if youve changed the syncros for 4th, than it could be an improperly adjusted clutch...it might not be disengaging all the way when you press the pedal all the way down
