clutchnet 2 problems?
Old Mar 18, 2002 | 09:05 AM
austrian type-R's Avatar
Default clutchnet 2 problems?
I have a clutchnet stage 2 with Fidanza flywheel and my thoughts on this combo is not good, but not too bad as for daily driving.
Well, the first 500 miles the clutch could not hold the power in 4th and 5th gear above 7000rpm. This is completly gone after 800 miles. But when I shift very quick it slips from 2nd to 3rd and from 3rd into 4th. Also when I´m at WOT and I hit a bumper @ 140mph the clutch starts sliping.
But the most thing I´m affraid of is, that the 3rd gear is starting to get hard in, usualy from 4th back into 3rd. What can this be? Sometimes I can press the stick realy hard, but I´m not able to get it into 3rd. I hope it is a clutch problem and not a tranny.
I don´t think the syncros are bad, cause there is not this grinding noise.
Old Mar 18, 2002 | 09:26 AM
b18bturbo's Avatar
Default Re: clutchnet 2 problems? (austrian type-R)
at high rpms the clutch net cluthc has problems disengaged fully thereby caushing you not to be able to shift correctly. I had the same problem as you did.
Old Mar 18, 2002 | 09:30 AM
Default Re: clutchnet 2 problems? (b18bturbo)
....and what have you done against it? Switched to another brand?
85preludeee
Feb 13, 2007 12:53 PM
94~GSR
Aug 1, 2006 12:43 PM
Norrod
Jan 30, 2006 06:52 PM
THMotorsports
Apr 28, 2005 09:27 PM
envious1320
Nov 11, 2003 05:06 PM
