shaking under acceleration..
Old 05-04-2011, 02:42 PM
8dxhatchy8's Avatar
Default shaking under acceleration..
so i have a 95 LS coupe 5 speed..just lowered on coils, when im driving around town its perfectly normal, never shakes..but after driving for about 15 or so minutes on the highway in fifth gear just cruisin about 60-65 it will start to shake and shimmy and you can feel it in the gas pedal as well .
but ONLY when i accelerate, not when i brake or when im at a constant speed...anyone know whats up? its pissin me off...thanks.
Old 05-04-2011, 04:51 PM
dntnedvtec's Avatar
Default Re: shaking under acceleration..WTF!
Wheels need balancing....Car needs alignment. Or your lug nuts are loose.
Old 05-04-2011, 04:55 PM
8dxhatchy8's Avatar
i just got new tires mounted and balanced
Old 05-04-2011, 05:10 PM
dntnedvtec's Avatar
hhrrrmmmm........interesting. Only when you acclerate....Worn bushings?
Old 05-04-2011, 05:12 PM
fcm
Old Fart
fcm's Avatar
Did you get a wheel alignment after you lowered it?
I would have the shop that did your tires recheck the balance, maybe a weight fell off. 94
Old 05-04-2011, 05:33 PM
dntnedvtec's Avatar
FCM, I was going to say the same thing, but OP mentioned that its only under load. cruising is not affected.
Old 05-04-2011, 06:11 PM
TheAsian's Avatar
I would say start by checking axles and axle nuts.
Old 05-05-2011, 12:00 AM
4DRmafia's Avatar
Check axles, it happen to me and came to find out it was a bent axle on my passenger side.
Old 05-05-2011, 02:54 AM
IN VTEC's Avatar
Inner cv joint is a common culprit.
Old 05-05-2011, 03:46 AM
8dxhatchy8's Avatar
yea i noticed my passenger cv boots are both ripped...time for a new axle im thinking
Old 05-05-2011, 06:48 AM
4DRmafia's Avatar
Try it and let us know how it goes.
Old 05-05-2011, 03:15 PM
8dxhatchy8's Avatar
for sure..well on the way to and back from work, which is 23 miles from my house it didnt shake at all...its really random when it happens
Old 05-05-2011, 04:29 PM
BoltonGSR's Avatar
My integra shook like that when accelerating, it turned out to be an axle. I payed the price for getting an autozone axle. Not saying for sure its the problem but it was for me.
Similarly,
My gf had this problem and it turned out to be her wheel bearings.
Isnt there a way to test the wheel bearings by jacking the front wheels up slightly and prying on them with a crow bar?
Old 05-05-2011, 05:31 PM
8dxhatchy8's Avatar
im not sure how to test, guess ill ask google
Old 05-07-2011, 06:04 PM
8dxhatchy8's Avatar
so i took a 140 mile round trip drive today and it shook off and on, but when it was shaking if i took a left turn around a curve it shook worse and when i went around a right curve it completely stopped!! ??
Random.Hero
10-03-2007 09:55 AM
gloryhog
02-05-2004 05:52 PM
wizzards581
06-19-2003 06:29 PM
DanielLaruso
17
05-11-2003 08:11 AM
wdyno
04-16-2002 11:13 AM
Quick Reply: shaking under acceleration..
