threw code 22 - vtec solenoid problem?
Old Feb 16, 2005 | 05:29 PM
SoCal ITR's Avatar
Default threw code 22 - vtec solenoid problem?
So I threw the code last night... but the engine seems fine and vtec is working, so... how do I check and see if somethings is really broken? Should I just unplug the battery and reset it to see if it happens again, or what?
I think it might be a fluke, because I was low on oil and I was in a sweeping turn at the time.
Thanks.
Edit: vtec solenoid is 21, sorry.... I threw 22, which is VTEC Oil Pressure Switch defective circuit or unplugged / defective oil pressure switch
that's according to http://www.c-speedracing.com/faq/05.php
Old Feb 16, 2005 | 05:41 PM
ZygSpeed's Avatar
Default Re: threw code 22 - vtec solenoid problem? (SoCal ITR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoCal ITR &raquo;</TD></TR><TR><TD CLASS="quote">I think it might be a fluke, because I was low on oil and I was in a sweeping turn at the time.</TD></TR></TABLE>
I did that once driving back home to Ohio to do an oil change.
At the time I almost **** a brick as I dropped out of VTEC during a long high speed turn, ... about to pass a mustang.
Old Feb 16, 2005 | 07:28 PM
B2FiNiTY's Avatar
Most likely because you were low on oil. Fill her back up and reset the ecu
Old Feb 16, 2005 | 08:15 PM
SoCal ITR's Avatar
Default Re: threw code 22 - vtec solenoid problem? (B2FiNiTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">Most likely because you were low on oil. Fill her back up and reset the ecu </TD></TR></TABLE>
Yep..... it was worse than I thought.. she took two quarts..
Old Feb 16, 2005 | 08:27 PM
kepani's Avatar
sorry to see chris. i still remember you having to add oil @ buttonwillow. hope the problem is remedied.
kepani-who wonders when the next track event will be.
Old Feb 16, 2005 | 08:34 PM
SoCal ITR's Avatar
Default Re: threw code 22 - vtec solenoid problem? (kepani)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kepani &raquo;</TD></TR><TR><TD CLASS="quote">sorry to see chris. i still remember you having to add oil @ buttonwillow. hope the problem is remedied.
kepani-who wonders when the next track event will be.</TD></TR></TABLE>
Yea, I think it's tiem to switch to 10w40... maybe that will help.
there's an event at streets on Friday through speed ventures, but I don't think anyone is going... then the only thing speed ventures is doing is buttonwillow (feb, mar, apr, and may) until the end of may... the next speed trials event isn't until may, also at buttonwillow.
Old Feb 16, 2005 | 10:34 PM
dk127's Avatar
Yep..... it was worse than I thought.. she took two quarts.. </TD></TR></TABLE>
wow... how low does it go before the oil light comes on?
Old Feb 16, 2005 | 10:58 PM
SoCal ITR's Avatar
Default Re: threw code 22 - vtec solenoid problem? (dk127)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dk127 &raquo;</TD></TR><TR><TD CLASS="quote">
wow... how low does it go before the oil light comes on?</TD></TR></TABLE>
Til you need about two quarts.
I added two, but could have gotten away with 1.5...
Old Feb 17, 2005 | 02:05 AM
petrv's Avatar
YOu really can go 2 liters low and the engine still runs? I am always worried about every milimeter below the max mark
Old Feb 23, 2005 | 08:58 PM
Incognito's Avatar
Default Re: threw code 22 - vtec solenoid problem? (petrv)
Add oil. Also, take the VTEC solenoid off the car (3 10mm bolts). Be careful when U actually pull the thing off the head. There is a rubber gasket there that U don't want to rip. Pull that gasket away from the VTEC solenoid carefully, with the metal screen part. Chances are you have some metal flakes/particles in there. Happens over time. Clean it out with brake cleaner, then slap it all back together.
ViXoN Hatch94
Nov 28, 2005 01:40 AM
allnapower
Apr 1, 2005 08:22 AM
singlecamcrx
Nov 24, 2004 02:10 AM
punkassazn
Oct 1, 2004 12:13 PM
danteisme
Sep 26, 2004 03:19 PM
