running issues
Old Mar 29, 2012 | 01:21 PM
Dustin Hunt's Avatar
Default running issues
just put a gsr motor in a teg and number two cylinder gets spark but the motor runs a little choppy and pulled number 2 spark plug wire off and didnt affect the motor could a injector be plugged up or does anyone have any other ideaS?
Old Mar 29, 2012 | 01:54 PM
Default Re: running issues
switched injectors didnt help
Old Mar 29, 2012 | 02:00 PM
tuck1crx's Avatar
define "a little choppy"
while driving? idle? part throttle? WOT?
also age and info of plugs wires and dizzy
what does #2 plug look like
Old Mar 29, 2012 | 02:09 PM
tegradb7's Avatar
Double check your wire at the distributor..
Old Mar 29, 2012 | 03:49 PM
B20ztek's Avatar
You can fry your distributor by pulling the plug wires while its running. You said number 2 is firing, what about 1, 3, and 4?
Old Mar 29, 2012 | 06:21 PM
third and fourth only first was firing then got second firing then drove it and went back to only 3 and 4 firing and sounded like a valve hit and it idled wrong part throttle same wot same but its a high compression b18c1 block wiht a stock rebuilt b16 pr3 head
Old Mar 29, 2012 | 08:35 PM
el crapitan's Avatar
your observations are a bit confusing.
so you did a power balance and found cylinders 2 and 1 to be dead? am i reading that right? so you have spark to cyl 1 and 2? but no change when wires are removed?
check your compression as per procedure
Old Mar 29, 2012 | 09:14 PM
compression is good it was about 215 across the board and first and second cylinder dont fire does not affect at all when you pull off the wire but it fired up and ran correct for about 10 mins then 1st and 2nd cylinder lost spark again
Old Mar 30, 2012 | 02:09 AM
tuck1crx's Avatar
What do 1st and 2nd plugs look like?
Has this motor been tuned?
Sounds like u may have a couple fouled plugs.
Old Mar 30, 2012 | 03:54 AM
ok. so you have no spark in cylinders 1 and 2?
Old Mar 30, 2012 | 07:16 AM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
When I did my gsr swap the book I was using gave me the wrong firing order so I fired it up and it was only running on #1 cylinder. Sounded like hell
3,4 is the firing order of the distributor
1,2
Old Mar 30, 2012 | 04:41 PM
Dhunt678's Avatar
thats the orderim using is 3 4 1 2 and plugs arent the greatest about to do a plug chop and no just have a base tune on a p28
Old Mar 30, 2012 | 08:38 PM
it doesn't matter which way the firing order is. that's not going to cause no spark
Old Mar 31, 2012 | 02:22 AM
tuck1crx's Avatar
Probably running a bit rich and fouled some plugs. Go get urself some Ngk bkr5e's and let us know what happens
bLu92bUbbLe
Jul 12, 2010 09:27 AM
charlieboyhonda
Oct 24, 2007 03:54 PM
LShatchie
Nov 17, 2004 02:55 PM
ipleadthe5th
Sep 12, 2004 06:02 PM
evilsolb16
12
Sep 6, 2004 09:11 PM
