Integra Dead, Hard CEL
Old Sep 7, 2009 | 10:47 AM
khondaacura's Avatar
New User
Default Integra Dead, Hard CEL
I am having a problem with my 92 integra, 1.8. The car cranks but will not start. No spark. Replaced distributor,ICM, relay unit, ground on thermostat. Still nothing. No fuel, fuel pump is not priming. When ignition is switched to on i have a hard CEL, wont go away after 2 seconds, main relay does not click (new one or old one), and fuel pump does not turn on. Voltage is present. when i jump the service connector i have a hard CEL. Any information would be helpful. Thanks.
Old Sep 11, 2009 | 01:08 PM
wpk24rsx06's Avatar
Default Re: Integra Dead, Hard CEL
that happened to me once and it was just the starter signal fuse the 7.5 under your steering wheel. it just cranked but it wouldnt start hope it helps
Old Sep 11, 2009 | 01:17 PM
90turbointegra's Avatar
Same thing happened to me about 2 weeks ago i replace just about everything.
Heres my thread on g2ic
http://g2ic.com/forums/showthread.php?t=196648
Check ur ecu and check fuses number 18 and 24 thats on the driverside kick panel. Those fuses run power to the main relay.
SHOOT DEERE IT
43
Jul 21, 2014 04:39 AM
rick_rabies
11
May 22, 2011 03:23 PM
jeephonda
Aug 23, 2010 11:08 AM
Tatooine
Jun 27, 2010 07:00 PM
hotinteggy
Oct 22, 2007 04:44 PM
