Rev Limiter
Old Mar 21, 2008 | 08:49 PM
TonyRomo's Avatar
Default Rev Limiter
I missed a gear in my stock gsr and hit rev limiter, anything to worry about? Seems to be running fine.
Old Mar 21, 2008 | 11:22 PM
SkaiWu's Avatar
the limiter is there so you can't go beyond that point...
mine was increased by previous owners brother so i better not miss anything lulz
Old Mar 22, 2008 | 04:45 AM
ls19integra95's Avatar
Default Re: (SkaiWu)
you should be fine, ive done that a few times now (wasnt paying attention ) and nothing is wrong with my car...
Old Mar 22, 2008 | 05:16 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Rev Limiter (TonyRomo)
A mechanical overrev is when you run into problems. The money shift is dowshifting from 3rd gear at redline to 2nd. The rev limiter doen't help there.
Old Mar 22, 2008 | 10:18 AM
TonyRomo's Avatar
Default Re: Rev Limiter (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">A mechanical overrev is when you run into problems. The money shift is dowshifting from 3rd gear at redline to 2nd. The rev limiter doen't help there.</TD></TR></TABLE>
Thats not what happened, I just left it in 2nd too long, so I guess you might not even consider that a miss shift.
Old Mar 22, 2008 | 11:06 AM
Winki's Avatar
My buddy did that in my car
good thing i have supertech springs
Old Jan 7, 2009 | 09:32 AM
steveharrmr23's Avatar
i peg my rpms off that ceiling alot cause i think is sounds funny and i have no problems and i got 260k on my motor so i think if any one would i would have some issues after doing it as many times as i have
Old Jan 7, 2009 | 11:53 AM
StokelesS_g2's Avatar
LoL, If you never bounced your redline before, then you've obviously never driven a Honda before.
Old Jan 7, 2009 | 12:57 PM
keepinitrehaal's Avatar
hahaha!
i've done is once or twice but everything is fine.
Old Jan 7, 2009 | 01:15 PM
autoxergsr's Avatar
I think i hit mine like half a dozen time almost every autocross heh.
Old Jan 7, 2009 | 06:18 PM
j_bizach's Avatar
missed upshifts and overreving are fine your rev limiter is ther for a reason to prevent damage to ur motor. On the flip down shifting and hitting to low a gear is mechanical over rev and very very very bad ther is no rev limiter since the wheels are driving the motor not the gas pedal. DOnt worry about it youve broke ur honda rev limiter cherry get used to it.
Old Jan 7, 2009 | 09:03 PM
milanoteg's Avatar
Revlimiter is made for bouncing off of
Old Jan 7, 2009 | 09:42 PM
mouab18c1's Avatar
who dont like to redline?
Old Jan 7, 2009 | 09:49 PM
NemesisCBR's Avatar
My shift light doesnt flash fast enough in 1st and 2nd so if im waiting for the flash instead of eyeballing, i end up bouncing the rev limiter but as they say, its there to protect you motor.
Old Jan 7, 2009 | 10:56 PM
majinsoftware's Avatar
^ lol, I use to have the same problem, I hooked my shift light up to a car alarm so now it makes a really loud buzz sound when im 400rpm off limiter and that gives me just enough time and warning to shift.
When racing you really dont want to hit limiter, Thats time wasted that could be use still accelerating in other gears and getting a better time.
Old Jan 8, 2009 | 06:27 AM
autoxergsr's Avatar
That depends, In autocross i use 225/45-13's whitch are a couple inches shrter than a oem tire and a lot of the time its faster to bang the rev limiter in 2nd a couple times than shifting to 3rd for a second then downshifting again. Whitch with my shorter tires i hit the top of 2nd a good bit.
Razr2
15
Jan 1, 2008 10:24 PM
Adam.
32
Dec 12, 2006 09:51 AM
hondadriver
Mar 10, 2006 12:51 PM
.M.
Jun 10, 2004 09:29 AM
1SlowSi
Feb 25, 2004 05:59 AM
