Rev Limiter
Old Aug 18, 2006 | 07:17 AM
Scud's Avatar
Default Rev Limiter
My car red lines at about 6200 or so and it just feels like it is still pulling pretty hard but then i have to shift.. is there anyway to over ride just the rev limiter?? and is it safe for the ls engine to rev over 6200??
Old Aug 18, 2006 | 07:21 AM
petergriffen's Avatar
Default Re: Rev Limiter (Scud)
on an ls i wouldnt rev past the sotck rev limiter
Modified by petergriffen at 11:32 AM 8/20/2006
Old Aug 18, 2006 | 07:26 AM
CleanLikeJdm's Avatar
Hype-R Stalker
ls limit shouldn't be 6200, it's more like 6800, but looks 7k, or over a small amount on the gauge.
Old Aug 18, 2006 | 06:03 PM
Scud's Avatar
Default Re: Rev Limiter (CleanLikeJdm)
it could be 6800.. the ls engine is in my civic so maybe my tach is off a bit but is there anyway to over ride the rev limiter?? like maybe let it redline around 7500 or 8000?
Old Aug 18, 2006 | 06:10 PM
BOOSTED RIVAL's Avatar
7500 to 8000 rpm do you want your pistons to uppercut your valves, the stock valve spring can't go that high
Old Aug 18, 2006 | 06:16 PM
lVlemphizStylez's Avatar
Default Re: Rev Limiter (BOOSTED RIVAL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BOOSTED RIVAL &raquo;</TD></TR><TR><TD CLASS="quote"> do you want your pistons to uppercut your valves</TD></TR></TABLE>
lol never heard that one before thats pretty good. No sense in going over 7k because the stock engine runs out of breath a little after 6500
Old Aug 18, 2006 | 07:22 PM
SlammedDC2's Avatar
Semper Fidelis
Default Re: Rev Limiter (lVlemphizStylez)
My brothers LS redlines at 7200 I think. Not sure how high you can safely go.
Old Aug 18, 2006 | 09:50 PM
jared99's Avatar
Default Re: Rev Limiter (SlammedDC2)
I've hit about 7500 on my stock LS for just a sec after a nasty missed shift. Didn't cause any damage but I wouldn't do it regularly.
Old Aug 18, 2006 | 10:09 PM
DPSJosh's Avatar
Default Re: Rev Limiter (jared99)
I saw 8 something on my LS after a HORRIBLY missed shift. Didn't hurt it at all. Changed the chip and put a 6800 cold and 7100 hot rev limiter on it. I have a straight back 2.5" exhaust with no cat so I probably make power until 7###rpms.
Old Aug 18, 2006 | 10:19 PM
Default Re: Rev Limiter (DPSJosh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DPSJosh &raquo;</TD></TR><TR><TD CLASS="quote">I have a straight back 2.5" exhaust with no cat so I probably make power until 7###rpms.</TD></TR></TABLE>
nah...you dont
Old Aug 19, 2006 | 05:39 AM
jared99's Avatar
LS power problems at 7k+ rpm's have more to do with the valves not being open long enough/not enough lift to get air into the engine...I wouldn't think it's because of not being able to get it out due to exhaust restriction. Sure less restriction helps, but at that RPM you're suffocating the engine. You'd need turbo or a different cam profile to breathe that high in the rev range. Honda's answer = vtec.
Old Aug 19, 2006 | 06:27 AM
Nors's Avatar
Yeah the LS makes peak horsepower is like a grand or so before redline. I ussually take it all the way to redline when driving hard so I will be in the powerband when I shift.
94-integra-ls
Feb 19, 2006 04:07 PM
bruce-si
Jan 21, 2006 09:31 PM
JDM00SI
Sep 17, 2004 01:14 PM
Project_SOHC_EX
Aug 20, 2002 08:52 PM
98 Ek LsVtec
Oct 29, 2001 11:05 AM
