how high do ls rev??
Old Oct 28, 2001 | 02:08 PM
98 Ek LsVtec's Avatar
Banned
Default how high do ls rev??
just wondering how high yall rev to safely?
[Modified by 98 Ek LsVtec, 3:09 PM 10/28/2001]
Old Oct 28, 2001 | 02:21 PM
MIKEGSR95's Avatar
New User
Default Re: how high do ls rev?? (98 Ek LsVtec)
Safely to 6200 RPM. Which is the factory redline. If you want to rev UNsafely, then go higher.
Old Oct 28, 2001 | 02:54 PM
SamuraiJack's Avatar
Default Re: how high do ls rev?? (MIKEGSR95)
redline is 6800 or 6900 rpm for the ls
[Modified by SamuraiJack, 3:54 PM 10/28/2001]
Old Oct 28, 2001 | 03:31 PM
360's Avatar
360
Default Re: how high do ls rev?? (SamuraiJack)
Yup, stock redline on LS's is 6800. On ls-vtec's, it all depends on what parts you use to build it up.
Old Oct 28, 2001 | 07:08 PM
Banned
Default Re: how high do ls rev?? (LuVaH)
well i did'nt build mine i just got the str block guard and z10 girdle i know for a fact that i can rev to 8000-8200 like the gs-r's but safley is the question.i just wanted to know what you guys shift at redlining so i can shift maybe a little over that point so i won't blow **** up thanks.
Old Oct 28, 2001 | 07:24 PM
degradated's Avatar
New User
Redline is 6800.
Rev limiter and fuel cutoff is around 7200.
It's safe to go to 6800 if you have a healthy motor.
Old Oct 28, 2001 | 07:36 PM
Variance-EJ-6's Avatar
New User
Default Re: how high do ls rev?? (degradated)
I have a LS, had it for a while, no rev limiter, you can take it to 7500 safely.....anything higher, and you will burn up seals and the such.....7500. I got one.....late
Old Oct 28, 2001 | 07:41 PM
degradated's Avatar
New User
Default Re: how high do ls rev?? (Variance-EG-6)
I've got an LS too...and my limiter is at around 7200 if I'm not mistaken.
It's not normal (or safe) to be without a rev limiter.
I wouldn't say that it's safe to take it to 7500 unless you've done heavy valvetrain work... So saying something like this does NOT apply to everyone.
Old Oct 28, 2001 | 08:39 PM
TeginRAGE's Avatar
New User
I have an LS and it rev's up to 7400 without a problem, it bounces off of 7500 so i guess my rev limiter is 7500, i wonder why ppl rev up to 6800 when they got another 400 rpms to go or maybe it's just my engine? *shrugs*
Old Oct 28, 2001 | 08:43 PM
b00st-0wnz's Avatar
From: Drinking Beer in sunny FL and jamming to Skid Row, USA
Default Re: how high do ls rev?? (TeginRAGE)
No it's your tach. The Tach is inaccurate.
Old Oct 28, 2001 | 08:56 PM
TeginRAGE's Avatar
New User
Default Re: how high do ls rev?? (Dave-ROR)
actually it's my stock rpm gauge and my apexi safc says the same thing also 7400, so does that mean my safc is wrong too?
Old Oct 28, 2001 | 09:01 PM
DgenosydeA's Avatar
New User
Well, its because the powerband isnt kept up for that long. It usually starts to go down after 6300rpm. Going higher just lowers ur powerband. Going on a dyno can prove this. And i must agree, even sources say the redline for LS's is around 6800-7000.
Old Oct 28, 2001 | 09:24 PM
teg92's Avatar
Default Re: how high do ls rev?? (DgenosydeA)
Yep I've got a 92 and redline on tach is 6800rpm, fuel cutoff is 7200rpm.
Old Oct 28, 2001 | 09:39 PM
OneThirtyEight's Avatar
Default Re: how high do ls rev?? (teg92)
to make a LS safely rev high, you have to upgrade valvetrain, and bottom end (oil squirters and a girdle) you can get 8000 with this.
Old Oct 28, 2001 | 10:55 PM
InfamousRS's Avatar
Default Re: how high do ls rev?? (97blackteg)
What is involved in putting oil squirters in a block. I have seen them in Vtec blocks before, they do not look like somthing that justs bolts in like a block gridle.
Old Oct 29, 2001 | 11:05 AM
New User
Default Re: how high do ls rev?? (BLK94RS)
BAH! too much work, heres what ive done....
Stainless Steel Valves
Dual Valve Springs
Titanium Retainors
JG 1001 RE-grind cams
Pressin 125 Shots of Nitrous
Pressin the limit with no REV LIMITER, been doin it for a season now....7500, EASY AND SAFE, I can go higher, but I WILL burn up seals and the such...late
EG-tofu
Honda S2000
91
Dec 2, 2007 05:45 PM
Scud
Aug 19, 2006 06:27 AM
631 Teggy
Mar 31, 2006 02:03 PM
Evil DOHC
Mar 26, 2004 09:42 AM
Project_SOHC_EX
Aug 20, 2002 08:52 PM
