Remote Start?
Old Oct 17, 2006 | 07:52 PM
shawn69's Avatar
Default Remote Start?
When i bought my 91 ls (5 speed) the previous owner said it has a remote starter, but the batteries were dead in the remote (so no way to test, i thought)
just a quick question does you clutch have to be bypassed for all remote starts to work? because mine isn't, so does this mean there is no remote start?
and what should i look for when i look for a remote start system?
(to see if there is one in the car)
Old Oct 17, 2006 | 09:08 PM
sooo_slow's Avatar
New User
Default Re: Remote Start? (shawn69)
Yes, there has to be a clutch bypass for the remote starter to work on a manual transmission vehicle. You may not see it b/c it could have been spliced then taped back up to look factory.
If you want to look for a remote start system, drop the lower dash panel under the steering wheel and look around for the module, you should see a black box with some of the wires going up towards the middle where your ignition wires and harness is.
Look for an antenna, a valet switch ( small little push button switch), check under your hood for a hood pin that would have been added, check by the coil to see if any wires were spliced or taped with another wire running back to your firewall/gromet.
Old Oct 17, 2006 | 10:42 PM
allm0torGSR's Avatar
Default Re: Remote Start? (sooo_slow)
Or just get a new battery for the remote, put the car in neutral (just to play it safe), and see if it remote starts.
Old Oct 18, 2006 | 12:36 AM
draXxus's Avatar
ya it also depends on which kind u have if u dont already know how to activate it some can be trickky like my frineds was ez u just held down a button another freinds u had to hold down 2 buttons at once so yaaa
Old Oct 18, 2006 | 01:27 PM
shawn69's Avatar
Default Re: (draXxus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by draXxus &raquo;</TD></TR><TR><TD CLASS="quote">ya it also depends on which kind u have if u dont already know how to activate it some can be trickky like my frineds was ez u just held down a button another freinds u had to hold down 2 buttons at once so yaaa</TD></TR></TABLE>
thats the problem i have no idea what kind it is, i'll get a picture of the remote soon... and i did try with a new battery but no luck
thanks for the help
Old Oct 18, 2006 | 03:26 PM
Default Re: (shawn69)
If you want to post a pic of the remote, I'm sure one of us will recognize it and be able to help you out.
There's 3 different ways I've seen a remote work to start a remote starter.
-One button, pushed once.
-One button, pushed twice.
-Two buttons, both pushed once at the same time.
And be sure when you push the button(s) that you push long enough. Holding down for a full second ought to do it, not just a quick push, that doesn't always send the signal completely.
Modified by allm0torGSR at 12:04 AM 10/19/2006
Old Oct 18, 2006 | 07:46 PM
ITR#132's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shawn69 &raquo;</TD></TR><TR><TD CLASS="quote">
just a quick question does you clutch have to be bypassed for all remote starts to work? because mine isn't, so does this mean there is no remote start? </TD></TR></TABLE>
No, it doesnt have to be bypassed for all remote starts. There is an output on the remote starter unit that sends a signal to the clutch switch for remote starting.
Those that bypass the clutch switch altogether just for a remote starter system, dont know what their doing.
Old Oct 19, 2006 | 04:26 PM
shawn69's Avatar
alright so here is my remote, there is also and antenna underneath my rear view mirror. anyone know what brand/model this is?
Old Oct 19, 2006 | 04:31 PM
shawn69's Avatar
sorry
Old Oct 19, 2006 | 05:18 PM
shawn69's Avatar
thanks for the help i found it... now i need to figure out whats wrong with it
if you can't read it says "Use ONLY on STANDARD Transmissions and Not on convertible vehicles." tu-3160 jan 22 1997
^^ the big black box
i think its made by ProStart
Old Oct 19, 2006 | 06:28 PM
shawn69's Avatar
where would the valet switch normally go?
look at the last page
http://www.engines911.com/asdo...3.pdf
Old Oct 20, 2006 | 04:21 AM
vtec8804's Avatar
* B A N N E D *
valet switches are normally tucked somewehere mine is tucked on the left side by the dead petal.
Old Oct 20, 2006 | 01:30 PM
shawn69's Avatar
Default Re: (vtec8804)
alright, because i found mine on the floor of my car! so thats why its not working hey?
haha thanks for all the help
alldemtingz
Audio / Security / Video
Sep 24, 2008 05:41 AM
tomu06
11
Mar 31, 2006 03:34 PM
BlUeDC2nEr
11
Dec 28, 2005 10:18 AM
sauceja
14
Sep 6, 2005 12:21 PM
Btothe3rdDegree
Mar 15, 2003 03:38 PM
