remote start
Old Mar 14, 2003 | 08:48 PM
Btothe3rdDegree's Avatar
Default remote start
ok i have a remote start on my 92 civic manual tranny. the guys that did the install partially installed the remote start but not all. if you try to remote start it the check engine light and battery light comes on like it is trying to start or it is on the "on" position. what else do i have to wire to get it to work?
Old Mar 15, 2003 | 02:04 AM
STSProtege's Avatar
Default Re: remote start (Btothe3rdDegree)
did it ever work correctly?
if there is no cranking at all, my guess is that the starter wire is not connected properly or the clutch switch was never bypassed. Possibly no tach connection either.
Old Mar 15, 2003 | 08:22 AM
Default Re: remote start (STSProtege)
no it never worked they installed just enough so the alarm would work properly. so i really have no idea what was installed and what wasn't.
Old Mar 15, 2003 | 10:31 AM
STSProtege's Avatar
well, your best bet is to look up under the dash and check for missing harnesses or non-connected wires from the main RS/Alarm unit and start testing. but by the sounds of it, maybe just a few wires need connecting.
Old Mar 15, 2003 | 12:54 PM
02silversi's Avatar
Well I know in IL it is not legal for a shop to over ride the clutch switch. I would say try the remote start with the cluch in and see if it does anything. It if starts then all you have to do is over ride the clutch switch.
Old Mar 15, 2003 | 03:38 PM
STSProtege's Avatar
Default Re: remote start (veener88)
the bypass (override) is only durning remote start, otherwise it works like normal.
i wasn't thinking before, i would suggest the aide of a pro to do this kind of install, an auto tranny isn't so bad, but when messing with a 5sp, disaster can strike. Trust me, you don't want that.
HiProfile
Audio / Security / Video
Dec 25, 2008 03:56 PM
Jap_Spec_Imports
30
May 26, 2006 05:43 PM
BigBlockCRX
Jun 16, 2004 06:24 PM
FourthGenHatch
Dec 2, 2002 10:39 AM
technine
Aug 23, 2002 05:42 PM
