SLS S200 Turbo Testing
Old Jan 23, 2006 | 11:13 AM
PSI2HI's Avatar
Former Vendor
Default SLS S200 Turbo Testing, 552whp/439trq
Got our hands on the first S200 and we went straight to the dyno w/ it. Spool up numbers would have drastically been increased but we didn't spend much time in the low rpm range so A/F up until about the 5000rpm range were 10:1.
Turbo specs:
56mm compressor/ 55lb/min
.76 AR T3 turbine
Results here:
http://www.dynotuneusa.com/turbocomparo
Based off the 30 psi graph it appears we maxed the little 55lb/min guy out. 32 psi only netted a 7whp gain over 30 psi.
Nick
SLS
Modified by PSI2HI at 9:17 PM 1/24/2006
Old Jan 23, 2006 | 11:15 AM
integra_gsr98's Avatar
Default Re: SLS S200 Turbo Testing (PSI2HI)
The car responded very well to this. I am excited to test the S300!
Old Jan 23, 2006 | 11:48 AM
igo4bmx's Avatar
you stole hondata's naming convention
and with that according to D@NNY, the s300 should break
Old Jan 24, 2006 | 05:48 AM
Default Re: (igo4bmx)
Bump for new turbo testing!
b18_ef_hatch
May 20, 2014 09:07 PM
MidShipCivic
Nov 14, 2006 01:32 PM
Turbo-LS
Dec 31, 2005 05:29 AM
jonvo
Oct 14, 2004 08:31 AM
wade
Sep 15, 2004 03:20 PM
