quick question about ABS after ITR sway install
my question is...
Would it be safe to zip tie the line to the sway bar??
as long as i keep it away from the bushing???
TIA
Re: quick question about ABS after ITR sway install (skunkintegra)
u can drill through the abs line bracket and bolt it right up with the sway bar mount..(just make the hole in the abs bracket the diameter of the swaybar mount and bolt them dwn together) i think i explained that right..im sure someone else will come along and correct me if im wrong...
Re: quick question about ABS after ITR sway install (teg-your-it)
i dont have the torque wrench anymore(to torque the sway brackets back down)
or the drill bit large enough drill the bracket
and i already took the brackets off...
Modified by skunkintegra at 1:49 PM 5/2/2003
go to my website.. and i have pictures of the install n instructions to the install. u can see what i did with the abs bracket and it looks a hell of a lot better than zip ties.
Clik here to go to My site n go to the diy section
EDIT: oh and u use the same drill bit u used to widen the lower mounting hole ok? so u should have that bit.. unless u borrowed tools n don't have them anymore.
As far as looks are concerned, nobody is gonna get down on the ground to see if you have a R sway bar anyway. Just ziptie it with black ones.
Re: quick question about ABS after ITR sway install (Brasspremier)
u dont even need to take the abs line bracket off, just drill the mounting hole out like u did for the sub frame. thats unless u cut the bracket up to get it off
Re: quick question about ABS after ITR sway install (AK94GSR)
didnt cut the bracket...just bent it up a bit...the protective coating that was on it is damaged...so it would rust badly now....its already zip tied up there....so its a done deal for now....thanks guys!! peace lata
