Questions!! Need answer
Old Jun 4, 2014 | 08:18 PM
Alcatrax30's Avatar
Default Questions!! Need answer
can i use that steel braided hose to replace the plastic one?? And how can i remove this bolt that broke off also the section that it broke off into is it part of the frame/chassis or can it be removed?
Old Jun 4, 2014 | 08:26 PM
B_Swapped93's Avatar
Default Re: Questions!! Need answer
yes you can and drill it out or get a bigger bit all together and overbore it then do the same to the rad support bracket it's self. As for getting it to hold simply use a nut n bolt I had that issues also only thing is I did a jdm front so I never really got to drill it. But I've done that procedure on other things using nuts n bolts works fine assuming g you have a full set of bits just pick the next biggest one.
Old Jun 5, 2014 | 03:39 AM
Alcatrax30's Avatar
Thank you! One last thing you see the section its stuck on? Is it part of the frame? Ive seen teggs that some people take it off but i cant find any bolts
Old Jun 5, 2014 | 06:46 AM
fcm's Avatar
fcm
Old Fart
That is the front upper bulkhead, [upper rad support] it is spot-welded in place, there are no bolts.
If you use a bolt/stud extractor for the sheared off bolt, you can save the nut. 94
Old Jun 5, 2014 | 07:46 AM
Alcatrax30's Avatar
[QUOTE=fcm;49761398]That is the front upper bulkhead, [upper rad support] it is spot-welded in place, there are no bolts.
If you use a bolt/stud extractor for the sheared off bolt, you can save the nut. 94[/QUO so if for some reason it gets damaged theirs no way to replace or repair it?
Old Jun 5, 2014 | 07:52 AM
The rad support? sure drill out like 30+ spot welds and grab a new one or do the jdm front. That's how to did my JDM front removed the entire front not hard at all just time consuming.
Old Jun 5, 2014 | 10:00 AM
Alcatrax30's Avatar
Ahh i see oh by the way whats that cone ive seen in some tegs its by the battery and looks like a intake ! Whats the purpose i cant find one
Old Jun 5, 2014 | 04:38 PM
fcm's Avatar
fcm
Old Fart
If it is by the batt. it will be the filter for a short ram air intake.
Like one of these...
https://www.google.ca/search?hl=en-G...og&sa=N&tab=wi 94
Old Jun 5, 2014 | 06:41 PM
Alcatrax30's Avatar
I changed that hose into metal one i bought that goes into the valve head from the manifold , whats the hose do ? Bring air to the head?
Old Jun 5, 2014 | 06:42 PM
Alcatrax30's Avatar
Yeah ive seen it but i mean they have a air intake but they install a cone one by the battery dont know what that do or called
Old Jun 5, 2014 | 09:26 PM
PCV valve
http://auto.howstuffworks.com/positi...ion-system.htm
Old Jun 6, 2014 | 09:55 AM
Alcatrax30's Avatar
Thanks really helps last thing , got a guy fixing dents but i dont have $ for paint so he said he will bondo and sand and primer, can the primer wet ? Or will bondo soak up h20?
Old Jun 6, 2014 | 10:05 AM
I don't know body work too well but iirc primer is meant to absorb liquid as when you're painting it helps make the base-coat/foundation. As for bondo I wouldn't get it wet seems like it would soak up water pretty badly.
Old Jun 6, 2014 | 10:45 AM
Alcatrax30's Avatar
Really? Because my car was out in the rain today but i was bondo then primerd so does this mean its ruined??
Old Jun 6, 2014 | 12:09 PM
fcm's Avatar
fcm
Old Fart
I would have to see a pix, but most likely it is just a filter with a cover.
I had my hood bondoed and primered for over 6mo wi5thout any problems, all that was done before painting was a light sanding and a second coat of primer was layed down as I had the whole car painted. 94
Old Jun 6, 2014 | 02:30 PM
Alcatrax30's Avatar
Im just scared it absorb water and start rust underneath
Old Jun 7, 2014 | 06:14 AM
fcm's Avatar
fcm
Old Fart
If your worried, grab a few "rattle cans" of your cars color, [or close as you can get] and cover bonded area with a few light coats, it can be sanded off when you paint. 94
djkina
Dec 27, 2014 07:10 AM
grumblemarc
28
Oct 24, 2011 05:21 PM
UserX826
10
Feb 21, 2009 10:02 PM
1.8
Dec 29, 2004 02:15 AM
ALF
Jul 7, 2001 10:31 AM
