This ecu program worth the cost and the specs?
Old Oct 9, 2003 | 09:07 PM
Rod.'s Avatar
Default This ecu program worth the cost and the specs?
It will be a 179 shipped. I want to have a chipped ecu is it worth it?
Also since a ls revs to 6800 and I get the rev to 8000 can i go that high without head work???
INTEGRA LS 94-95 (p75) ,(program)Prospeed Spec N/A ,(new revlimit)8,000 (upgrade )More fuel and timing
Old Oct 9, 2003 | 09:09 PM
PrecisionH23a's Avatar
Default Re: This ecu program worth the cost and the specs? (redturbocivic)
In my opinion chips are all a waste of money. Each motor is different and requires different fuel and timing tables. You are better off just purchasing s-afc. As far as rev limits, is your motor even making power past 6800 stock?
Old Oct 9, 2003 | 09:21 PM
DaveF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redturbocivic &raquo;</TD></TR><TR><TD CLASS="quote"> Also since a ls revs to 6800 and I get the rev to 8000 can i go that high without head work???
good luck..thats more than 1000 rpm more than stock. i wouldnt rev a stock engine any more than 200 rpm past stock revlimit..thats just asking for bad things to happen.
ps...ls rockerarms love to fly off @ high rpms.
Old Oct 10, 2003 | 02:34 PM
Rod.'s Avatar
Default Re: This ecu program worth the cost and the specs? (GudeH23a)
Not that i know of. I already have a s-afc...so just stick with that?
Old Oct 10, 2003 | 02:47 PM
PHiZ's Avatar
No you can't rev to a grand past redline on stock head. Well you could. Once.
$180 is a little on the high side for a plug and play chip. Always get your chips througha reputable seller, there is NOTHING wrong with them, especially if they were dialed in on a similar car.
Most of the stock "mugen" jun" "skunk2" chips, without modification are going to run pig rich.
-PHiZ
Old Oct 10, 2003 | 03:11 PM
T-RO's Avatar
Read the 19 pages of the Uberdata thread and do it yourself...
superbeastcrx
Sep 17, 2005 07:20 AM
pinoyboy204
Jan 24, 2004 07:28 AM
nY's FiNeSt
Aug 21, 2003 08:53 PM
abs0lutexer0
Aug 4, 2003 10:18 AM
jdmrealm
Dec 30, 2001 05:40 PM
