Why wont' it start?? =(
Old Dec 8, 2003 | 03:17 PM
SpoolinEK's Avatar
Default Why wont' it start?? =(
sorry for the repost but. i just swapped a 94 dx engine into my 93 si and it isnt' starting..it cranks and spark..but will not start
Old Dec 8, 2003 | 03:33 PM
Kendall's Avatar
Default Re: Why wont' it start?? =( (EG Civic)
Have you checked out the fuel system?
Old Dec 8, 2003 | 03:55 PM
mattssi's Avatar
Default Re: Why wont' it start?? =( (dc231)
Have you went over all the grounds?
Old Dec 8, 2003 | 05:56 PM
Jimmy's Avatar
Global Moderator
Check,fuses,fuel,all grounds and then come back.
Old Dec 8, 2003 | 08:46 PM
SpoolinEK's Avatar
Default Re: (USDMDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDMDC2 &raquo;</TD></TR><TR><TD CLASS="quote">Check,fuses,fuel,all grounds and then come back.</TD></TR></TABLE>
i've check all fuses..the fuel is running and all ground is connected..let me say that the car was in an accident also..but never hit the engine..my cousin said it didnt' start because the battery died..maybe that might help
Old Dec 8, 2003 | 10:22 PM
cxSHOE's Avatar
Default Re: (EG Civic)
coil, ignitor
Old Dec 8, 2003 | 10:23 PM
SpoolinEK's Avatar
Default Re: (cxSHOE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cxSHOE &raquo;</TD></TR><TR><TD CLASS="quote">coil, ignitor</TD></TR></TABLE>
would that be a problem even if it's giving spark?
Old Dec 9, 2003 | 07:15 PM
doublejz's Avatar
check the injectors, if your fuel pump is priming and you have spark well they aren't meeting each other. just take 12v to your injectors and see if they click
Old Dec 10, 2003 | 11:53 AM
zangiefisgod's Avatar
might be the distributor or the clutch sensor isnt engaging.... try pushing the clutch down real hard
Old Dec 10, 2003 | 12:48 PM
Jimmy's Avatar
Global Moderator
Default Re: Why wont' it start?? =( (zangiefisgod)
Why would you but a d15b in an si???
Explaination please..
Old Dec 10, 2003 | 01:07 PM
SpoolinEK's Avatar
Default Re: Why wont' it start?? =( (USDMDC2)
because i blew my d16...and i have two extra d15 blocks laying around..MINI ME swap(soon)
Old Dec 10, 2003 | 02:28 PM
boostlee's Avatar
are the spark plug wires on correctly? did you swap out the engine computer too or does the ecm work on both d16 and d15?
http://www.cardomain.com/id/boostlee
muhaMan
Jul 3, 2007 10:01 PM
love_5gen
11
Feb 25, 2007 11:22 PM
DAcraze
Mar 3, 2006 06:22 PM
JBG's Ferio
Jul 31, 2003 09:14 AM
Hondasaurs
Apr 9, 2003 05:16 PM
