oil in 1 & 3 spark plug help
there is oil only in 1 & 3 spark plug but not in the rest. The oil is only on the thread of the spark plug not the firing tip. I change my grommets recently.
Re: oil in 1 & 3 spark plug help (B18CRacer)
ok best case senario, the seals at the top of the spark plug tubes between them and the valve cover are crap. Senario 2, you spilled oild down there on your last oil change. #3 worst, piston rings are fried and or a valve leak. Try a compression and leak down test.
VTEC_Du_Ma_Mai
09-05-2008 01:41 PM
gixxer6
10-29-2002 01:10 PM
