OBD2 o2 sensor problems
Old Sep 1, 2010 | 04:56 PM
JDM Like Whoa's Avatar
Default OBD2 o2 sensor problems
My car (98 GSR) started to throw these two codes:
P0138 - O2 sensor circuit high bolts (bank 1 sensor 2)
P0136 - o2 sensor circuit malfunction ( bank 1 sensor 2)
So I replaced the secondary o2 with a Bosch one from the auto parts store. I bought one of the ones you wire up yourself to work. Upon startin the car, the two original codes were gone but it threw a code for secondary o2 heater malfunction. Just to be sure that it wasn't bullshittin me, I cleared the code but it came right back a few minutes later. I read the diagram correct but I was wondering if it will make a difference if the two same colored o2 heater wires were mismatched. There isn't really a way to tell because they are the same color. Anyone else have an idea on this or maybe a different solution? Hell, even to maybe just get rid of the second o2 all together or something but this CEL is killin me. Thank you.
Old Sep 2, 2010 | 07:54 AM
Default Re: OBD2 o2 sensor problems
Bump
Old Sep 2, 2010 | 11:40 AM
dpetro1's Avatar
honestly i dont know anyone that has success with the universal type o2 sensors. grab a direct fit denso or ntk and see if that fixes the problem
Old Sep 2, 2010 | 03:16 PM
**** I wish I had the money to right now. Is there a way around it with like a simulator or something?
Old Sep 2, 2010 | 06:04 PM
HondaPartsHero's Avatar
Technical Hero
http://www.o2sensorsimulator.com/
Old Sep 2, 2010 | 07:47 PM
racebum's Avatar
ngk makes a secondary o2 that retails around 120, you could also run a jdm ecu which does not use this sensor, its plug and play.
that code does not retard timing so its annoying to look at buy doesn;t effect how the car runs, mpg or hp
i would save till you can afford a real one. the only reason you;ll need it is emissions and any bypass will not work when you get your car smoged
Old Sep 5, 2010 | 05:19 PM
Well, thank God I don't have to worry bout emissions testing. Gonna give the NGK one a go on payday.
importdreamer
May 26, 2007 06:58 PM
mxl36o
Aug 4, 2006 06:09 PM
teg2000gs
Oct 26, 2004 11:02 AM
cu3tip
Oct 18, 2004 08:26 PM
Phoenix_ITR
Jul 9, 2003 04:21 AM
