brake problem
Old Sep 5, 2010 | 04:35 PM
almostvtec's Avatar
Default brake problem
i have a 92 ls and i just changed my rotors and now when i drive theres a constant squeaking and almost a grinding when i come to a stop. so i took it apart two times to see if i missed anything and its still doing the same thing.
Old Sep 5, 2010 | 05:00 PM
Integra4lyfe069's Avatar
Default Re: brake problem
did u squeeze caliper pistons back in?
brake pads imo need changing,
Old Sep 5, 2010 | 06:19 PM
almostvtec's Avatar
that was my first thought maybe the caliper piston wasnt all the way in so i made sure to press it back in and still the same problem. i looked at my rotors and it looks as if the pads are kinda wearing into the rotors
Old Sep 5, 2010 | 07:15 PM
Drive 4 fun's Avatar
Spin each wheel by hand and find where the problem is, then look at that assembly. Also careful feel/touch of the rotor will give you a quick hint of a pad is dragging. Don't burn yourself. Dust shield if not hot, lots of noise but no heat. Just a starting place.
Old Sep 5, 2010 | 07:21 PM
I would try to figure out what it is, not hide it. I guess squeeky wheel get grease, but I like to know the cause.
Old Sep 5, 2010 | 07:29 PM
almostvtec's Avatar
yea me too id like to figure out the problem also. im gonna jack it up and put it on jackstands and see if i can spin the wheel to see if thatll work
Xathine
Mar 15, 2009 10:03 AM
bibong
Feb 6, 2007 01:01 PM
nomoreavril
Dec 13, 2006 02:47 PM
JKingCivicSi
Apr 16, 2006 01:10 PM
klomast3r
Jan 30, 2006 11:10 PM
