NOS!
Old Jul 1, 2001 | 10:51 PM
B00ST2nR's Avatar
Default NOS!
Does anyone have some information on NOS Octane Booster?
I have two bottles of NOS Octane Booster: Racing Formula. Will it jack my engine up if I use it? It's not the Nitrous Oxide System, its just some liquid that you put into the gas tank. I heard that it gives you 5-10HP throughout the whole powerband...
I need some info on this before I actually use it. I want to be sure and safe. So if you know anything about this NOS Octane Booster: Racing Formula, then let me know. Thanks!
Old Jul 1, 2001 | 11:46 PM
crookedletterd's Avatar
New User
Default Re: NOS! (GS-Racer)
just use gobs and gobs of it!
the bottle o' throttle
Old Jul 2, 2001 | 08:09 AM
GSRwBOOST's Avatar
Default Re: NOS! (Teken)
It's ok to use.. i have heard it's not good to use all the time.. but thats yet to be proven to me..
Old Jul 2, 2001 | 08:49 AM
GSRacer's Avatar
New User
Default Re: NOS! (GSRwBOOST)
why not just go get race gas at the track?? I prefer puttin in $15 of 100 octane gas then to pay $12 for the dumb octane booster.
Old Jul 2, 2001 | 09:07 AM
HX_Guy's Avatar
Default Re: NOS! (GSRacer)
Why would you use it if you dont need it?
If you car doesnt have a high compression ratio...higher octance gas doesnt do crap for it.
Old Jul 2, 2001 | 10:11 AM
Chris's Avatar
Default Re: NOS! (HX_Guy)
exactly!!..Or excessive advanced timing...
Old Jul 2, 2001 | 11:52 AM
berkel's Avatar
Default Re: NOS! (Chris)
Hey all,
With my limited knowledge, I believe it works like this:
For financial reasons, you should run the lowest octane gas that doesn't make your car ping. Octane represents the resistance of the gas to pinging. More octane promotes a SLOWER burn.
You may benefit (more power) from higher octane gas IF you are able to take advantage of more octane by advancing timing. For example, if the ECU is pulling timing because the knock sensor detects ping, you may not pull as much timing with more octane to prevent the pinging. Also, more octane is insurance when running advanced timing, high compression, or forced induction.
Other than that, it really won't help you except through weight reduction from a lighter wallet....
Also, there has been some debate whether octane boosters even increase the octane. I have heard (mostly from the Audiworld board) that the NOS Octane booster is the most efficacious at actually increasing octane, but you aren't necessarily increasing it "that" much. For example, if you have 94 octane Sunoco and add NOS octane booster which may say it adds 6 "points," are you really at the equivalent of 100 octane?
Does anyone have data on how effective they are?
Thanks,
FB
metal-x
Aug 30, 2002 02:40 PM
MintyDip
Aug 16, 2002 10:12 AM
BlwnBlue
May 2, 2002 03:45 PM
Mr. Vapor
Apr 20, 2002 04:27 PM
Etylorcen
Oct 24, 2001 11:24 AM
