is this normal? idle
Old 03-22-2007, 04:57 PM
emooheo's Avatar
Default is this normal? idle
I had a rip in my throttlebody gasket so i replaced it, when replacing it i also messed with the idle adjustment screw.
my question is: is it normal for when you step on the gas and it goes down to idling rpms (800) to immediately bounce up to about 1200 rpms and go back down to 800, then stay there?
thanks
Old 03-22-2007, 05:00 PM
わたしは。。。
E.J.'s Avatar
Default Re: is this normal? idle (emooheo)
No, that is not normal. It seems as if your throttle is sticking. Not sure with how to fix it, try messing with the throttle cable, seemed to have worked with a friends problem.
Old 03-22-2007, 05:03 PM
thecunningham's Avatar
Default Re: is this normal? idle (E.J.)
Check your throttle cable, make sure its not too tight. You should have 1/2 to 1 inch of up and down slack.
Old 03-22-2007, 07:02 PM
emooheo's Avatar
hmm interesting.. the throttle cable is as loose as it gets, and has enough slack.
i have also noticed that if my idle adjustment screw is out to where idle is at about 900, my idle will bounce from 900 to 1500 and back and forth for about 30 seconds then it stays at 800-900 until driving around, then it will start bouncing again. fixes?
Old 03-22-2007, 07:47 PM
jorge59la's Avatar
Default Re: (emooheo)
throttle body's are a bitch! why did you mess with the idle screw if u were reaplacing the gasket???
-i have the same problem and im thinking of replacing mine with an oem or type r.
Old 03-22-2007, 07:50 PM
Haleiwa-Brando's Avatar
Default Re: (jorge59la)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jorge59la &raquo;</TD></TR><TR><TD CLASS="quote">throttle body's are a bitch! why did you mess with the idle screw if u were reaplacing the gasket??? </TD></TR></TABLE>
No kidding and this makes no sense at all.
Bust out your HELMS manual and re adjust the idle per spec. It takes all of two minutes to accomplish.
Old 03-23-2007, 02:34 PM
emooheo's Avatar
Default Re: (Haleiwa-Brando)
i messed with the screw becuase people have said it stops the whisling the skunk 2 IM causes, which it did stop. my idle was just all bouncy, i turned the screw all the way in, my idle is at about 600-700 but still if i give it some gas in neutral it will go to 3000 rpms (or whatever amount i give it) and come back down to idle then bounce back up to 1400 then come back down to idle after about 2 seconds
gabrielsousa
05-02-2014 07:53 AM
FATKID87
Honda CR-V & Element
03-26-2014 07:52 AM
asocallocal
09-23-2010 06:20 PM
shooitzlinh
01-08-2005 09:52 PM
MeanGreenEG9
03-06-2003 09:19 PM
Quick Reply: is this normal? idle
