NOOB QUESTION
Old May 25, 2007 | 03:39 PM
YAH YAH's Avatar
Default NOOB QUESTION
I know this is a noob question but i have a 2000 gsr and how do i use the trunk latch?
Old May 25, 2007 | 03:41 PM
Padawan's Avatar
Darth ModerVader
Default Re: NOOB QUESTION (chiboi800)
As long as the doors aren't locked, just slide the lever on the hatch to the left and it will unlatch. You can also use the key in the keyhole to open the hatch.
Old May 25, 2007 | 03:45 PM
YAH YAH's Avatar
Default Re: NOOB QUESTION (Padawan)
yeah it doesnt work. is it becuase of my alarm. i use the key to open it.
Old May 25, 2007 | 03:53 PM
1.8L_allmotormilitia's Avatar
put key in twist to right and open latch. thats how mine is i guess the 98+ trunks never work.
Old May 25, 2007 | 03:54 PM
Padawan's Avatar
Darth ModerVader
The key should open it regardless because it's purely mechanical. If the doors have been electronically locked with the switch (or an alarm), the lever won't work. Depending upon how your alarm is wired, I suppose it's possible that it's interfering with the operation of the hatch release.
Old May 25, 2007 | 05:17 PM
dagimp415's Avatar
mines the same. The lever seems pointless. Turn the key to the right and hold it there while you lift the hatch with your other hand.
Old May 25, 2007 | 05:23 PM
98GSRrdr's Avatar
Default Re: (dagimp415)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dagimp415 &raquo;</TD></TR><TR><TD CLASS="quote">Turn the key to the right and hold it there while you lift the hatch with your other hand.</TD></TR></TABLE>
This is how my friends worked , and how it was when he got it . No clue why ..
Mine I just use the latch .. 98 GSR
and I never had to use the keys but to start the car (keyless entry)
and wow mt joy, local guy good to see
Old May 25, 2007 | 05:27 PM
YAH YAH's Avatar
Default Re: (98GSRrdr)
thanks alot. yeah. i guess it doesn work. but if anyone seems to work let me know with directions if theres some special way. thanks for the replys
Old May 25, 2007 | 06:25 PM
()()DC2's Avatar
yea ****** gay 98+ laches!!! arent they suppose to fix problems with newer car!!!
Old May 25, 2007 | 07:46 PM
b20acura's Avatar
Default Re: (()()DC2)
you have to put the key in and turn it all the way, then you have to turn it just a bit more till it kinda of just ticks. and when it "ticks" you gota lift the hatch up while the key is in the position. thats how mine is. the lever doesnt do crap for me.
Old May 25, 2007 | 10:57 PM
jdancer987's Avatar
my 2000 latch also has never worked, kind of annoying when someone needs to get in the trunk when the car is on, but eh whatcha gunna do
billybod
Jun 21, 2019 05:31 AM
abda53
Jan 12, 2006 10:53 AM
mkiv98
Dec 26, 2004 12:29 PM
Outperform
May 16, 2004 06:00 PM
jamal-188
Audio / Security / Video
Mar 1, 2002 05:00 AM
